tranny: downshifting from 5th to 4th
Old Nov 30, 2011 | 01:17 PM
stck_trbo_mnstr's Avatar
Had the car for a while, but the other day I went to downshift from 5th to 4th and it made a grinding noise. It does not do it all the time but ever since that they every once in a while when I downshift to 4th it grinds the gear, or makes that noise.
what could this be and how can it be fixed.
Old Nov 30, 2011 | 05:45 PM
Old Dec 1, 2011 | 03:44 PM
can anyone gimme some input?
Old Dec 1, 2011 | 04:00 PM
tscompusa's Avatar
is it only doing it in 4th gear? if so the synchronizer is probably getting worn out in that gear. requires a transmission rebuild to fix.
if you shift into 4th very slow does it still grind? if not that would confirm the syncro.
Old Dec 1, 2011 | 04:43 PM
yea if i shift into the gear real slow it wont do it.
Old Dec 2, 2011 | 10:38 AM
MechTech's Avatar
Are you rev matching?
Old Dec 2, 2011 | 10:41 AM
Planglie's Avatar
3/4 synchro is worn. Rev matching will help. Probably needs synchro, slider & maybe the gear.
Paul
Old Dec 2, 2011 | 05:32 PM
88888's Avatar
Paul
this
Old Dec 2, 2011 | 05:46 PM
4G63 T's Avatar
most likely synchro
