fuel problems
Old Dec 3, 2011 | 10:37 AM
acssa's Avatar
fuel problems
I run E50(50 Ethanol mix)
HTA 3582
2.2l stroker
340 Aeromotive
1250cc bluemax injectors
I am sitting at 98% injector duty cycle at 30psi! (12 AFR(
How can that be?!
Old Dec 3, 2011 | 11:30 AM
CurseDSM's Avatar
It can be because you have to small of injectors. Do the formula and that should tell you the correct size.
cfm of turbo x .33= + cfm of turbo gives you the minimum injector size for e85
while I was searching for cfm for the turbo I couldn't find it but I will tell you right now you should be in the 1600 range for injector
Old Dec 3, 2011 | 12:27 PM
acssa's Avatar
68 lb/min = 980 CFM
in the formule you posted it comes to around 1308cc...
Old Dec 3, 2011 | 12:36 PM
CurseDSM's Avatar
Thanks for the info acssa. So with that said 1450s would be a good choice or like I said 1600s would be more then enough head room.
PHILLY EVO
Jul 23, 2015 08:56 AM
Fuel Injector Clinic
Nov 29, 2013 09:04 AM
yitzac1990
10
Aug 9, 2010 06:08 PM
turbotekray
May 27, 2010 02:20 PM
Evo442
Dec 26, 2006 08:47 PM
