Need help quick
Old Dec 10, 2011 | 12:14 PM
marcusE's Avatar
Need help quick
Ripping out the transfer case that is whining to send out to be rebuilt and I'm stuck on this last suspension cradle bolt/nut
The bolt itself is not accessible from the top whatsoever.. It's built into the actual frame itself. The nut will not thread off past the point it is at and is spinning the bolt with it.
I have used prybars to put pressure inbetween the nut and bolt and I am also using air tools...
What can I do to get this nut off?
Old Dec 10, 2011 | 12:53 PM
mithrandir7533's Avatar
Yikes, that has happened to quite a few people on here. You'll have to cut into the area above it to gain access to the area to secure the bolt down. If the bolt is spinning freely you've broken what was holding it in there. Frame shop should be able to fix it.
Old Dec 10, 2011 | 01:04 PM
marcusE's Avatar
Car has the exhaust removed, front driveshaft removed and both axles and is on a lift. Dont really have the means to take it to another place.
Old Dec 10, 2011 | 01:21 PM
AndyCT9W's Avatar
Just throwing this out there. Since you have undone the nut a bit and no thread is exposed, would that have pushed the bolt up? Is is possible the bolt has been pushed out of the slot that holds it in place? Possible to pull the bolt back down into that slot?
I've never worked or gone near my t case so I'm just wildly guessing.
Old Dec 10, 2011 | 03:16 PM
marcusE's Avatar
I believe from the factory that bolt was welded into the frame, After so many years and Harsh northern winters the impact from the air gun torquing on it broke the weld and is now making the bolt spin I think..
Good idea though
Update : I used an air saw and started sawing off the nut can I cut through to get access to the top of the bolt and then reweld once we have the new one on?
Neeed some input here fellas.
Old Dec 10, 2011 | 05:53 PM
marcusE's Avatar
Ttttt
Old Dec 10, 2011 | 06:09 PM
ChanseEvo8's Avatar
Registered User
I personally never had to remove the cradle to access the TC. I usually unbolt the front and rear motor mount, lift the radiator up half way, then rock the motor forward and then drop it down. (downpipe, licp, and all that good stuff from the bottom of the car has to be removed)
Old Dec 10, 2011 | 06:14 PM
marcusE's Avatar
Right, my new problem is this Bolt braking its weld in the frame......
Old Dec 10, 2011 | 08:41 PM
marcusE's Avatar
I have to figure something out by tomorrow ... someone anyone
Old Dec 10, 2011 | 09:38 PM
cfdfireman1's Avatar
heat the nut with a torch until cherry red then use a 1/2 impact as you pry down on the part above it. no oxy acetylene torch? grab an ordinary road flare. they burn at about 1400 degrees.
Old Dec 11, 2011 | 08:11 AM
marcusE's Avatar
I've already cut the nut in half.. I'm going to have to re thread the bolt with a new nut.... Problem is I have no access to the top of the bolt without cutting into the frame to access it.
Old Dec 13, 2011 | 08:51 PM
Clean the threads as best you can and try to spin the nut on with an air gun. A little side force on the bolt as you do it will help.
shooterblaze250
For Sale - Part Outs
33
Oct 22, 2012 08:07 AM
Diversion
For Sale - Cars For Sale
Jul 26, 2012 02:09 PM
marcusE
Mar 23, 2012 06:06 AM
sacul33
Jan 26, 2012 02:05 PM
unsungboxer
Dec 4, 2011 08:51 PM
