Boost/Camshaft Problem
Old Dec 30, 2011 | 01:36 AM
JSPturbo's Avatar
I have a problem with a Turbo on my Evo 5:
Turbo TD06H 25G
Exhaust 3"
Tephra Tuned with E85
Intake 80mm
And other mods,pump,etc....
The boost donīt up to 21psi from 4500rpm to 7500rpm !!! I tried to adjust the wastegate bolt and nothing,no leak boost, wastegate spring is ok and the boost controller is ok.
I thing the problem maybe is the stock cams, maybe possible not to give more power or "pressure" to move the bigger turbo ??
Thanks !!
Old Jan 20, 2012 | 12:21 PM
JSPturbo's Avatar
Anyone has this problem with Stock Cams ??
