TD05HR turbo shaft play.. rebuild or replace??
Old Dec 31, 2011 | 06:21 PM
stevolution84's Avatar
Hi, I have a JDM stock Evo 8 TD05HR and I seem to have a bit of shaft play. I saw the housing had a bit of different colour due to the wheel rubbing on it and the ends of the fins on the wheel had a bit of different colours too.
My question is, is it worth rebuilding with a kit such as:
http://www.ebay.com/itm/220617218452...#ht_7117wt_971
Or do I need to replace my whole turbo?
It still boosts fine and no boost fluctuations.
Thanks in advance!
Old Dec 31, 2011 | 06:51 PM
milford's Avatar
are you trying to keep the car close to stock? if not very expensive to pick up green or red. perfect time to upgrade.
Old Dec 31, 2011 | 06:54 PM
Hendrixmx's Avatar
IMHO, I would never use ebay parts on a turbo.
Old Jan 1, 2012 | 10:21 AM
YogSaahoth's Avatar
Veteran: Army
^^this is pretty good advice. Don't risk it.
There isn't much you can do with rebuilding an 8 turbo...my old 8 turbo is sitting on a display shelf in my living room. Find yourself a used 9 turbo (or new for about $1000), or call up FP/CBRD/MAP and see what they can offer you
Old Jan 1, 2012 | 10:49 AM
evo unknown's Avatar
You can find used Evo 8 turbos for sale in the classified section on here. Most will be in great condition that you can just bolt right on and you won't have to change a thing.
It is not worth rebuilding, especially with some ebay parts.
Old Jan 8, 2012 | 11:28 PM
EVO8emUp's Avatar
http://www.ebay.com/itm/Mitsubishi-L...item4160a6c1d3
EvoIX89
Oct 12, 2016 04:53 PM
harlintuliau1
Dec 3, 2013 04:05 PM
DaveSlow
Sep 9, 2011 10:21 AM
sphynx
Jun 16, 2011 07:36 PM
Mitsu.kid.02
Lancer Aftermarket Forced Induction Tech
27
Oct 1, 2010 09:56 PM
