Fic lower seals
Old Jan 5, 2012 | 03:35 PM
DSMolition's Avatar
Fic lower seals
Picked up some Fic 850's with no lower seals. I figured i could just re use my stockers. When i took the seals out of the manifold and put them on the new injectors they are super loose. Does anyone run them like this or should i get the upgraded vinton seals...
I don't want any boost leaks or idle issues. Thanks
http://www.fuelinjectorclinic.com/cg...ey=SLK-125-6X4
Old Jan 5, 2012 | 04:02 PM
Fastone_evo6's Avatar
the indjectors have a diffrent lower size whare it fitts the inletmainfold ,
thats why the seals are bigger , you need to get the right seals whit the right thickness
Old Jan 5, 2012 | 05:21 PM
fre's Avatar
fre
Just order a set from FIC, they sell just the lower seals. Your best bet is to just call them and explain what you need. It is easy to get a hold of them and they are very helpful.
Old Jan 5, 2012 | 05:30 PM
DSMolition's Avatar
Ya i just order a set for 25.00 free shipping. I figure I mite as well as replace all of them. Thanks for the help. I just didn't know if people used the factory ones some how.
