Brake kit options for 15" wheels.
Subscribe
Jan 15, 2012 | 05:15 AM
I am planing to run 24.5" M&H slicks with 4.11 gearing on my Evo, so I am in the market for a front brake kit which will fin under 15" wheels.
My initial plan was to keep the original look as much as possible, If I can find a 24"ish slick which will fit in 16" wheels I will go with that but I coudn't find any so I guess I am going to run 15" slicks at the track, 18" wheels on the road.
Thanks to STM they listed the weight of the original brakes; "with slightly worn pads and rotors, the OEM assembly (per side) weighs 31.6 pounds. Each OEM rotor was 21.6."
My car will be driven on highway and need high speed braking power I guess AMS Rally Kit is more suitable for me even it is slightly heavier than the others.
1- Brake Man Drag Kit $2090
Quote:
Billet forged aluminum caliper
Calipers weigh only 3 lbs each
BM Rotors
BM Pads
LINK TO ITEM
2- STM / Willwood Drag Kit $1050 / $1100
Quote:
4 Piston Calipers
Street Brake Pads
Wilwood Rotor [Standard or Scalloped]
Choice of STM Anodized Hat Color [Black, Purple or Gold]
STM Brake Lines
Scalloped rotors are 2.7 lbs. lighter than STD rotors
Complete weight of 14.4 / 11.7 lbs. per side [Measured STD / Scalloped]
Complete rotos weight of 9.25 / 6.55 lbs. per side [Measured STD / Scalloped]
LINK TO ITEM
3- AMS / Willwood Drag Kit $1199.95
Quote:
32lbs. of weight savings, 22lbs. of which is reduced from rotating mass!
4 Piston Caliper
2 Pcs Alu. Hat Discs
Goodridge S.S. Steel Brake Lines
BP-10 medium friction compound brake pads
Complete weight of 15.6 lbs. per side [Calculated]
LINK TO ITEM
4- AMS / Willwood Rally Kit $1649.95
Quote:
24lbs. of weight savings, 20lbs. of which is reduced from rotating mass!
4 Piston Caliper
Steel Brake Lines
B compound brake pads
Complete weight of 20lbs. per side [Measured]
LINK TO ITEM
5- English Racing Small Brake Kit $570.00
Quote:
Iron 2 piston calipers
Iron rotors
Tested on low 10sec / 140mph cars.
Weaker than the factory Brembos but are acceptable for daily driving
Upgrade to crossdrilled or slotted for only $100
LINK TO ITEM
REVIEW
Reply 0
Jan 15, 2012 | 05:48 AM
+1 on info
Reply 0
Jan 15, 2012 | 01:38 PM
I hope posting this is ok, but here's what I did for very little cost and I've been running them for 2 months with no problems whatsoever.
http://www.dirtyevo.com/showthread.p...ht=small+brake
Reply 0
Jan 15, 2012 | 08:11 PM
^^^ tyvm!!!!
Reply 0
Subscribe
