Just pulled the 03 Evo motor. What to do now
Old Feb 6, 2012 | 08:33 PM
korizmo's Avatar
There was 108000 when this happened. I have 880cc injectors going on it
Old Feb 6, 2012 | 08:41 PM
korizmo's Avatar
I see what your saying about a new oil cooler. damn I already spent around 4k for everything. Wouldn't want to ruin that. Anyone have recommendations for somethin around 200.00?
Old Feb 6, 2012 | 09:13 PM
Chef-j's Avatar
Idk if you can get for 200 bucks, but i like setrab oil cooler. I think MAP selling those for 500?
Edit: maybe you can pick up decent ones from summitracing and fab that.
Old Feb 6, 2012 | 09:31 PM
EvoFredo's Avatar
THIS is for you my friend, good luck with your build
http://www.streettunedmotorsports.co...proclassic.htm
Old Feb 6, 2012 | 11:49 PM
okevolutionVIII's Avatar
Originally Posted by korizmo
The shop down the road disassembled it and put it back together. I know they reused the stock tube, added a new oil pump, so for the oil cooler should I flush it out?
Get a STM oil cooler delete kit for $20, it blocks off the 2 oil lines at the oil pump. Once the motor is well broke in, find a good used oil cooler(off a running engine) or upgrade to a STM piece at a great price. This is what I'm doing and it'll keep you from damaging a new motor and will keep the new oil cooler clear of any major metal shavings from break-in.
Old Feb 7, 2012 | 09:01 AM
korizmo's Avatar
The oil cooler delete kit sounds good for a temporary break in. The temps here are around 70 degrees during the day and i'm not going to be beating on it.
Old Feb 7, 2012 | 12:29 PM
korizmo's Avatar
Went ahead and ordered the oil delete kit. I will run that for the first 1500 miles. After that 3rd oil change I will run the STM setup.
korizmo's Avatar
thanks
Old Feb 7, 2012 | 12:30 PM
korizmo's Avatar
delete
korizmo's Avatar
Sorry all but I need 15 post to sell some stuff. haha. and i'm done. Thanks all
Gotta try and make some money to finish this up.
Old Feb 9, 2012 | 09:33 AM
scrivs's Avatar
Same thing happened to my motor... Ever definitively figure out the cause?
Old May 23, 2012 | 06:38 AM
korizmo's Avatar
scrivs - detonation from bad gas. They took a sample and determined that the gas was lower ocatance - around 90
UPDATE for everyone
Purchased a 9 turbo and sent it off to be upgraded to 71HTA, FP Wastegate, and 84mm comp cover. Also I have added a jmf o2 dump and will be running a little bit of methanol. Buschur intercooler also... The engine has about 1700 miles on it and is running strong. I still haven't been able to go WOT in 1700 miles. Still on a partial throttle break-in tune.
I did beat my friends 2004 Cadillac CTS-v only running him from a stop with half throttle and shifting at 6500 rpms
Gotta love AWD
JohnBradley
165
Jun 7, 2018 02:53 PM
kaj
19
Jul 21, 2015 01:15 PM
LimitlessEvo7
Nov 9, 2014 02:53 AM
ambystom01
Jul 20, 2014 03:55 PM
korizmo
Mar 27, 2012 11:42 AM
