My Nightmare...
Old Jan 20, 2012 | 05:28 AM
batty200's Avatar
Your bov spring should be as light as possible while holding closed at idle and holding boost up top. Any tighter is just going to kill your turbo. If your car is using speed density then opening at idle isnt even too bad except a small amount of unfiltered air but if it holds boost the kightest spring possible is best. That is why the factory uses a recirced valve so under heavy vacuum no unfiltered/unmetered air enters and the spring can be very light.
Old Jan 20, 2012 | 05:36 AM
jameswwt's Avatar
Hi Batty200, thanks for yr kind sharing and you mean i should turn back to a softer spring rate on my bov???
Old Jan 20, 2012 | 05:37 AM
jameswwt's Avatar
Originally Posted by RJSP
Hi jameswwt, it could be that both bov you are trying are having opening/venting trouble because being set too stiff (too much spring force and preload). If you further restrict the venting of the bov it won´t get better.
Like other are suggesting, try with the softest spring with no additinal preload and see how that goes, if it works then you can start adjusting for a balance between responce and driveability.
Thanks Ricardo...
Old Jan 20, 2012 | 05:38 AM
mt057's Avatar
As said, start by adjusting the bov.
Running without one is not the best idea. It will cause the air to bounce off the throttle plate and slam against the compressor blades.
Old Jan 20, 2012 | 06:24 AM
mitsuevoX's Avatar
I agree with everyone else. When the bov spring is too stiff it closes the bov too fast which causes air to be kicked back and cause surge. Terrible for your turbo.
Old Jan 20, 2012 | 07:04 AM
wazzelby's Avatar
1. DO NOT close off the BOV hole and make any runs. That will kill your turbo in a heartbeat!!
2. take out those stiff double springs and put the softest spring you can in the BOV.
If the spring is too stiff the BOV cannot respond to a pressure change when letting off the throttle. This will cause bucking and "surging" since the pressurized air has nowhere to escape to and reverses direction causing pressure to slap back against the blades on the turbo. This causes that "surging" you feel as the air tries to stop the blades from spinning abruptly.
Adding a stiffer spring may help keep the bov closed under high boost pressure but it can't do it's job correctly when you let off the throttle. As stated, go with the softest spring you can that barely holds the bov shut when idling. When you tap the gas you should see it slam shut fro teh vacuum/pressure change. The spring does not control the BOV under load, the vacuum/pressure does the work.
Old Jan 20, 2012 | 07:29 AM
n2oiroc's Avatar
Originally Posted by jameswwt
Thanks N2oiroc but even b4 i change to turbosmart race port bov its happen on my sard r2d2 bov also...When im on stock turbo, there is no such plm...
Can i just temporary completely closed the bov vent hole and make a few high speed run and see if the plm still occur?
Can this method works to check whether i need a stiff bov spring?
it happened when you changed the turbo and cams right? the s2's dont pull as much vacuum and vacuum is what opens the bov. bigger cams need a softer spring. i wouldnt run without the bov, just do what you can to soften up the spring rate.
Old Jan 20, 2012 | 10:47 AM
jameswwt's Avatar
Thank you so much Guys...I truly appreciate all yours sharing...+1
Old Jan 20, 2012 | 11:02 AM
MechTech's Avatar
Don't forget to update us if this fixed the problem or not!
Old Jan 20, 2012 | 11:17 AM
jameswwt's Avatar
Will definitely do...Now it 3.30am over here...
Old Jan 20, 2012 | 11:31 AM
deylag's Avatar
I would suggest getting your Evo looked at by a tuner and get it retuned if you plan to use the stiffer springs. Also if you are running vta you should be on Speed Density if you are not then return to a recirculated setup.
Old Jan 20, 2012 | 09:13 PM
jameswwt's Avatar
Thanks Guys, and as Chinese New Year holiday is just 2 days ahead, will only able to update you guys next week.
But a kind forumer advise me to set my profec b II boost controller and he didnt mentioned abt the spring stiffness issue. He just ask me to slightly turn down my Gain and see how it goes.
Old Jan 21, 2012 | 03:11 AM
jameswwt's Avatar
Ive tried turning down my boost controller profec b II "Gain" and the most i can go down is 5% and its doesnt work...
Have took a short video but unfortunately its really too shrot but please pay attention on the beginning and you guys will see my boost meter goes hairwire just when i lift off the throttle a bit.
http://youtu.be/-Nn9OpKmECE
The boost was stable whenever i full throttle.
What happening??? Some forumers said my bov spring is too stiff and before i added the extra spring this problem is already there?
Old Jan 21, 2012 | 05:47 AM
mt057's Avatar
Unless there is a frayed wire, or a messed up vacuum line. I do not see how the profec could be causing it. I run the same boost controller and never had that issue. Post up all or your setting for it.
Old Jan 21, 2012 | 07:45 AM
jameswwt's Avatar
Ive a shared vacuum line for my Bov & Fpr from the intake.
2nd is another vacuum line from the intake to my boost controller and meter.
Ive tried swap Bov line sharing with the boost controller + meter and direct intake to Fpr but the problem still happen!
Btw, after i make the swap, my car started to knock...Even after i swap back to the previous arrangement the knocks does go away until ive to go for a fine tune again...
