head studs and injectors necessary??
Old Jan 16, 2004 | 09:58 AM
evilution8's Avatar
soon in my evo i will have 3" turboback, electronic boost control, and SAFC II. i was wondering with these types of upgrades installed would i need or be wise to install either injectors or head studs?? thanks for the info.
Old Jan 16, 2004 | 02:53 PM
EvolvedDSM's Avatar
You wouldn't need either. Your money would be better spent on an EGT or logging device.
Old Jan 16, 2004 | 04:25 PM
bpclements's Avatar
I definitely reccomend getting an egt and datalogger also. The injectors and fuel pump would only be neccessary if you plan on running the max boost out of the turbo. I'd go with a Walbro 255lph just to be safe. The head studs would only be neccessary if you plan on upgrading to a larger turbo.
