Stock Head Bolts
Stock Head Bolts
I do not want to cause an alarm or anything. I changed my cams last week and I changed my head bolts to ARP as well.
Just checking the torque on the stock head bolts, I found out that the last 2 headbolts (I think its cylinder 4, its the one to your right looking under the hood) only had around 50ft lbs of torque!!! Some were close to 78ft/lbs, but some are definitely loose. To be fair, I have gone as far as 22-23psi with my MBC for short sprints (split seconds) before when I was tuning my boost to 20psi to redline.
They were DEFINITELY loose. I think it is recommended to at least tighten these bolts, specially if you are keeping 19psi to redline or when you go beyond 19.5psi anywhere!!!
STi
STi
