j-pipe to turbo gasket leak!
Old Mar 10, 2012 | 12:15 PM
EvoRinga's Avatar
after doing a boost leak test today we discovered a major boost leak coming from j-pipe to the turbo. I have a new gaskets and was wondering if it was a PINA to replace the gasket before I even start to try. thanks
Old Mar 10, 2012 | 12:33 PM
YogSaahoth's Avatar
Veteran: Army
Nope. Straight forward as anything. All you need is ratchet extenders and torque specs...small hands help too
Old Mar 10, 2012 | 12:34 PM
EvoRinga's Avatar
thank you
Old Mar 10, 2012 | 05:54 PM
Boost Demon's Avatar
Veteran: Air Force
You can also use a little bit of red RTV on each side of the gasket to help seal it.
Old Mar 10, 2012 | 07:05 PM
Mikey@Spec-Ops's Avatar
bold
Old Mar 12, 2012 | 07:39 PM
EvoRinga's Avatar
I changed the gasket. It looked fine when i took it out. It holds boost a little better but still leaks. I will try a little rtv gasket and see how that works..
seven10
Nov 29, 2016 09:42 PM
lghtngyello03
19
Jun 25, 2015 05:30 AM
vr4gasmtt
Jan 7, 2015 12:56 PM
Evo23IG
Oct 21, 2012 03:52 PM
miragevo
22
Oct 31, 2010 10:08 PM
