New cam angle sensor no fire.
Old Mar 11, 2012 | 09:01 PM
Boostfiend's Avatar
I installed a new cam angle sensor and now the car will not start. Fired up with the old sensor, does the cam angle need to be adjust because its off or could it be the sensor? Thanks.
Old Mar 11, 2012 | 09:04 PM
AWD96's Avatar
The CAS needs to be reassembled the EXACT way it came off. Take it out, and double check to be certain you didn't put it in right
Old Mar 11, 2012 | 09:57 PM
Boostfiend's Avatar
There's only one way for it to go on...*scratches head* The bolt goes through the CAS and into the hole. It does angle a little to the left or right if that's what you mean.
Old Mar 13, 2012 | 11:14 AM
AWD96's Avatar
It's been a while since I did my cams, but I believe it needs to be set in the exact position it was removed.
http://www.evomoto.com/tech_articles..._article_id=18
Refer to post #28, I could be wrong but just figured I'd throw a suggestion out there.
