Hanging RPM's at WOT
Hey guys,
I have a 2005 VIII, 83k miles, 26 psi. I bought the car modified and haven't messed with it. I've had it for two years and put 50k miles on it. Not sure all that is done to it or of the tune, but it has run perfect until two days ago.
Under WOT my RPM's will hang at about 3-4k. My boost gauge stays the same and my speedo goes up. There seems to be a loss of power and gas mileage.
Any ideas?
Any ideas?
clutch will only "slip" when it's all the way engaged, otherwise it's already being slipped by the driver
go ~65 on freeway in 5th gear and floor it, you'll be able to tell if the clutch is slipping
^dont floor it in 5th - this is easier:
have your car in a parking lot or similar (flat surface) park/stop the car then (e-brake off) put the car into 3rd or 4rd and slowly release the clutch out in small increments if the car stalls its not your clutch if it moves forward slowly/slightly without the use of the accelerator your clutch is slipping
I noticed my stocker was slipping just on feel alone while racing a bike, watched the next gear and sure enough it was rev-hanging at 5k until the driveline caught up. If I wasn't accelerating while it did that I wouldn't have beaten said bike.
Sounds like a sensor...like a TPS or a MAP. If you cant rev it out past 4k, that's probably it. As far as the clutch is concerned, its probably fine, clutches don't just stop your car from revving out randomly. If it was slipping, you would be revving up and not going anywhere.
i have the same thing goin on, i can rev past 4k though no problem, could it be sumthing with the stock tune? cuz i googled the problem and the X's have that problem from there factory tune? could it possibly be the same for the VIII's?
no, there not binded up at all, i was replyin to the statement about the sensors, i just went outstide quick, started the car, put it into 4th, released the clutch slowly, it moved forward like 6 inches, then it stalled. so wats the verdict?
I have heard this is a common problem on the 8 and can be tuned out. I also have a 2005 evo 8 with 70k and sometimes the revs will hang around 4-5k after doing a pull and putting the car into neutral
