-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Hanging RPM's at WOT (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/603808-hanging-rpms-wot.html)
eaneumann Mar 21, 2012 07:28 PM
Hey guys,
I have a 2005 VIII, 83k miles, 26 psi. I bought the car modified and haven't messed with it. I've had it for two years and put 50k miles on it. Not sure all that is done to it or of the tune, but it has run perfect until two days ago.
Under WOT my RPM's will hang at about 3-4k. My boost gauge stays the same and my speedo goes up. There seems to be a loss of power and gas mileage.
Any ideas?
s.e.a.n. Mar 21, 2012 07:45 PM
Slipping clutch
eaneumann Mar 21, 2012 07:54 PM
Originally Posted by s.e.a.n. (Post 10050587)
Slipping clutch
Even though its already engaged? Crap lol.
llDemonll Mar 21, 2012 11:03 PM
clutch will only "slip" when it's all the way engaged, otherwise it's already being slipped by the driver
go ~65 on freeway in 5th gear and floor it, you'll be able to tell if the clutch is slipping
DaGr81 Mar 22, 2012 05:58 AM
^dont floor it in 5th - this is easier:
have your car in a parking lot or similar (flat surface) park/stop the car then (e-brake off) put the car into 3rd or 4rd and slowly release the clutch out in small increments if the car stalls its not your clutch if it moves forward slowly/slightly without the use of the accelerator your clutch is slipping
escodotcarter Mar 22, 2012 06:02 AM
Slipping clutch
if it was a slipping clutch then wouldnt the rpms shoot up and the speedo not move. the OP is stating the opposite.
cmspaz Mar 22, 2012 08:53 AM
All depends on how worn the clutch is and where he's flooring it from.
I noticed my stocker was slipping just on feel alone while racing a bike, watched the next gear and sure enough it was rev-hanging at 5k until the driveline caught up. If I wasn't accelerating while it did that I wouldn't have beaten said bike. ;)
2ndLaw Mar 22, 2012 03:03 PM
Sounds like a sensor...like a TPS or a MAP. If you cant rev it out past 4k, that's probably it. As far as the clutch is concerned, its probably fine, clutches don't just stop your car from revving out randomly. If it was slipping, you would be revving up and not going anywhere.
ReignMan24 Mar 26, 2012 10:23 AM
i have the same thing goin on, i can rev past 4k though no problem, could it be sumthing with the stock tune? cuz i googled the problem and the X's have that problem from there factory tune? could it possibly be the same for the VIII's?
PsychDr. HN$ Mar 26, 2012 10:32 AM
Is your throttle cable binded up?
ReignMan24 Mar 26, 2012 10:56 AM
no, there not binded up at all, i was replyin to the statement about the sensors, i just went outstide quick, started the car, put it into 4th, released the clutch slowly, it moved forward like 6 inches, then it stalled. so wats the verdict?
quochung123 Sep 20, 2012 05:16 PM
Ghys I have a problem evo 7 gsr. Gears 3 won't pass 3.5rpm when I gas it but if I take my.foot of the gas for.abit hen.gas it again it allows me to pass the 3.5rpm any idea what the problem is?
quochung123 Sep 20, 2012 05:18 PM
What is a tps or map?
Evophil Sep 26, 2012 02:51 PM
I have heard this is a common problem on the 8 and can be tuned out. I also have a 2005 evo 8 with 70k and sometimes the revs will hang around 4-5k after doing a pull and putting the car into neutral
tschad Sep 26, 2012 06:55 PM
I'd check to make sure your map sensor is plugged in (sensor between intake pipe and cone filter)
