Spring/Retainer and Valve Suggestions
Old Apr 13, 2012 | 02:32 AM
TURBO_S2K's Avatar
My only mod right now is HKS DLI, Evo 9 Turbo and 3'' Cutout with Tune
I already purchased a set of GSC S2 Cams, HKS Cam Gears and ARP L19 Headstuds for my Evo 8.
I want to rev 8K without any problems.
Which springs/retainers should I go with??
Cosworth? HKS? GSC Beehive? Ferrea?
Also which valves do you recommend?
Old Apr 13, 2012 | 02:31 PM
TURBO_S2K's Avatar
anything??
Old Apr 13, 2012 | 02:34 PM
evo8426's Avatar
I didn't replace retainers when I did cams and springs. I used MAP beehives. Also, there is no reason to rev to 8000rpm on stock turbo, peak power is before 7000rpm
Old Apr 13, 2012 | 02:52 PM
boostfeddevo9's Avatar
Same here I just replaced the spring's with Map Beehive's and I'm running kelford 272's
Old Apr 13, 2012 | 03:47 PM
GSR ONE's Avatar
I'm doing a full Ferrea valve train with beehive springs and GSC S2 cams but I also plan on running an ETS FP HTA3582R in the future so planning ahead.
I've heard these springs can rev to 10,000RPM but don't quote me on that.
Old Apr 13, 2012 | 05:21 PM
fre's Avatar
fre
Kiggley is the best, but overkill for only 8k rpms. I use Brian Crower Springs/titanium retainers and rev to 8600 rpm no issues.
Old Apr 13, 2012 | 05:41 PM
JNProject's Avatar
do you guys know who makes map beehives springs?
Old Apr 13, 2012 | 06:46 PM
mcm308's Avatar
you got the single 95# springs ?
Old Apr 13, 2012 | 07:17 PM
evo8426's Avatar
A1 Technologies is what my box says
Old Apr 15, 2012 | 02:14 PM
fre's Avatar
fre
That sounds right. 95lbs of preload.
Old Apr 15, 2012 | 02:20 PM
bryanf's Avatar
I would go with the GSC beehive springs, why not you have the cams already. I used this exact set up and I haven't looked back.
Bryan
Old Apr 15, 2012 | 03:08 PM
Blue91lx's Avatar
I use the BC Springs/Retainers with S2s. Never had any issues.
Old Apr 15, 2012 | 03:27 PM
Levar's Avatar
Veteran: Army
I personally use the GSC stage 3 springs and retainers.
Old Apr 15, 2012 | 03:35 PM
TURBO_S2K's Avatar
I guess I will be going with the MAP Beehive Springs and MAP Valves and keep the stock retainers
Should I get a port polish done on the head? (stock size valves) Would it make a big difference on stock 9 turbo?
Old Apr 15, 2012 | 03:42 PM
Blue91lx's Avatar
You'll make more power on less boost. Until you get a turbo capable of pushing more air, you may not see too many gains.
