Turbo giving me trouble, ALOT!
Old Apr 28, 2012 | 12:42 PM
ajnasrah20083's Avatar
When the turbo starts to spool up on my evo, the car starts to jerk really badly. When I go WOT, the car makes 10lb's of boost (usually makes 15lb's) and then doesn't want to make more but start's jerking really bad also. This started after I went to the movies on a really rainy day. I let my cousin drive the car, and he desides to get on it, on a rainy day -_-. I am assuming that water got into the turbo, or motor. I looked over all the piping and nothing was loose. I cleaned the intake thinking maybe the turbo isn't getting enough air, but no luck.
Old Apr 28, 2012 | 01:43 PM
fre's Avatar
fre
Look for boost leaks, that will cause what you are seeing, especially with a MAF (stock air flow sensor) car.
Old Apr 28, 2012 | 01:57 PM
But this happened on our way back from the movies. Could have something came loose during the time it was parked?
Old Apr 28, 2012 | 02:01 PM
prowakeskater's Avatar
yeah something got loose. check your piping, then check your MAF plug.
Old Apr 28, 2012 | 02:16 PM
Strict7gsr's Avatar
Maybe there's water trapped in the intercooler pipes Its happened to me before...
Old Apr 28, 2012 | 02:46 PM
fre's Avatar
fre
Stuff can pop off at any time while boosting. Not saying it can't be water, but if you have a good air filter that shouldn't be an issue.
Old Apr 28, 2012 | 03:11 PM
I cleaned my Maf out and it's still doing it. Everything was tight, I guess my only route now is a boost Leak test. I will try it tonight
Old Apr 30, 2012 | 04:40 PM
I did the boost leak test, no boost was leaking. No shaft play in Turbo and no oil underneath it or around the Turbo.
Old Apr 30, 2012 | 05:02 PM
I really need this problem resolved ASAP so someone please help!
Old Apr 30, 2012 | 05:16 PM
awdordie's Avatar
Kinda sounds likke my problem... minus the jerking. I also boost leak checked my car and found nothing. If you find something let me know please.
Old Apr 30, 2012 | 06:24 PM
evolved0414's Avatar
Did u check ur spark plugs? The gap may be too wide. Itll be a 10 minute fix if thats the case
Old Apr 30, 2012 | 07:23 PM
If it were the spark plugs i don't think the car would decide to misfire when ever the turbo spools up, but that will be my next step. I took apart all piping and blew (with a compressor) pressurized air and put the car back together, yet it still does the same thing. While driving it, i said **** it and stayed WOT even while jerking very rapidly and then the exhaust started popping loudly. It is still making 10lb's of boost though. Any other suggestions?
Old Apr 30, 2012 | 07:40 PM
Just give it a shot bc i had the same exact symptoms a few years back. I would hit 10psi and my car would start jerking bad. I never would have thought it would be the plugs either but my friend told me that was def the problem so i decided to give it a try and pulled the plugs and regapped them and that solved the problem.
Old Apr 30, 2012 | 07:44 PM
Chef-j's Avatar
I will defi check plugs first. Any cel yet?
Old Apr 30, 2012 | 07:58 PM
finalflash_17's Avatar
I had same issue before....exhaust leak...bad gaskets...good luck
