bulletproof drivetrain!
Old May 1, 2012 | 12:10 PM
CtSilver03Evo's Avatar
Originally Posted by iloveturbolag
These help keep the diff in the subframe
What the hell is that thing? lol
Old May 1, 2012 | 07:16 PM
batty200's Avatar
Billet rear diff cover.
Old May 1, 2012 | 07:33 PM
SmurfZilla's Avatar
Originally Posted by barneyb
At 700 hp the clutch isn't even considered a part. It is a consumable like gasoline.
Quoted for truth. Although you can get decent life if you aren't drag racing at every life.
Old May 1, 2012 | 07:50 PM
Boltz.'s Avatar
FCOTM Winner
Built trans w/ billet output shaft, upgraded ring and pinion in the T/C, carbon driveshaft, upgraded rear diff, upgraded rear axles, solid differential mount, upgraded motor mounts....
Car will be completely obnoxious on the street, but pay to play.
Old May 2, 2012 | 01:16 AM
Blue91lx's Avatar
If you have the option (TRE cough), shot peening stuff really helps strengthen the metal.
Basically, by shot peening metal, internal compressive stress areas are formed which work against the tension stress areas which helps prevent fractures in the metal.
Old May 2, 2012 | 01:53 AM
jebiga's Avatar
for the tcase would shot peening the standard ring and pinion be an option to go along with the wavetrac? as i heard its usually the diff in them that goes boom!
Old May 2, 2012 | 06:41 AM
iloveturbolag's Avatar
@silver03evo
Its a Billet rear diff cover made by Frontline Fabrication, they are coming out with a billet valve cover for evo's as well.
Old May 2, 2012 | 09:07 AM
SmurfZilla's Avatar
Price?
Old May 2, 2012 | 11:34 AM
Frew's Avatar
I know some people might think its a waste but I have seen good things from cryo treating and micropolishing, research that I have seen has shown a decrease of 7% of friction on a surface after it has been cryoed and micro polished. This is more like an afterthought to all the other things to toughen your drivetrain, don't expect to cryo your stock tranny and it's good for 1000 whp
Old May 2, 2012 | 01:07 PM
Chef-j's Avatar
What for? Drag? Or just street? I think you can worry about drivetrain after build that high hp motor.
Old May 2, 2012 | 11:02 PM
shattered-4g63's Avatar
Originally Posted by deeman101
No such thing as bulletproof drivetrain. This will never be a subaru. But you can give yourself the best chance by optioning up everything from shep's website. Billet output tube, stage2 or 3 tcase, quaife/wavetrac front diff, and REMing everything.
What do you mean by "This will never be a Subaru" ?
Old May 3, 2012 | 12:40 AM
OG's Avatar
OG
I think he's trying to say that Subarus have bulletproof drive trains?
Old May 3, 2012 | 02:54 AM
rick1024's Avatar
he means the motor was built properly, and we dont have to worry about air/oil seperators, blown head gaskets, cracked pistons, yada yada yada
Old May 3, 2012 | 04:17 AM
SmurfZilla's Avatar
Busted ringlands on a crappy factory tune. LOL.
Old May 3, 2012 | 05:26 AM
rick1024's Avatar
i love this excuse i got from a friend who spun a bearing
"subaru uses abnormally tight bearing clearances"
so i guess everyone else is just loose
