Installing performance injectors
Old May 11, 2012 | 06:47 AM
robotech's Avatar
I have evo4 with evo8 engine and evo8 turbo.
I am planning to improve it's performance with keeping lag as smaller as possible so I will be looking for installing evo9 turbo.
I am willing to get around 400hp.
Currently engine is being rebuilt - forged pistons and so on.
I hope get car till summer. However turbo upgrade is scheduled after summer.
So the questions is - does it make sense to change injectors/fuel rail/pressure regulator now or when I install the newer turbo and we try to get those 400hp?
I am advised to buy Injector dynamics 1000cc injectors. I counted that for 400hp it's ok to have 700cc injectors. If I buy 1000cc will this affect engine in any way? The point is that 1000cc Injector Dynamics is the popular model.
Old May 11, 2012 | 07:21 AM
Brent_si's Avatar
I would go ahead and upgrade the injectors to like 1000-1200cc's. That way you dont have to do it in the future if you plan to make more power. I think the stock injectors would work fine for around 400 hp. A bigger injector can make the car harder to idle but ive seen fic 2250's idle just fine.
Old May 14, 2012 | 06:31 PM
VIIIdriver's Avatar
I broke 400hp on a Evo9 turbo and my injectors were right about 105% idc so you'll need to get bigger injectors to accomplish your goal.
Old May 14, 2012 | 09:41 PM
Thore's Avatar
1450cc will get you to mid 700whp. (Q16)
Depending on if you are self tuning or having a shop do it, the new injectors will need to calibrated.
Old May 15, 2012 | 08:05 AM
robotech's Avatar
So it's worth to upgrade them now
Old May 15, 2012 | 09:26 AM
ChaseH's Avatar
I have some cheap FIC 750cc if you are looking for 400whp.
Old May 15, 2012 | 10:41 AM
robotech's Avatar
Well, I am not aiming so high. At least now. As a goal I see 400hp on evo9 turbo with low lag.
We have very small tracks with extremely sharp corners and higher lag is unacceptable disadvantage.
Thank you for your idea about calibration. Most likely I will leave this upgrade to autumn when there will be done custom manifold, evo9 turbo and evo8 ecu.
Old May 15, 2012 | 10:42 AM
robotech's Avatar
Thank you but I am going to buy very exact model - ID of 1000cc.
Old May 15, 2012 | 10:43 AM
robotech's Avatar
That's actually not a question whether to upgrade or not. I will upgrade them for sure. Question is if to upgrade them now or in 4 months when there will be turbo upgrade.
Old May 20, 2012 | 02:50 PM
djdnav's Avatar
Do everything at once, or you'll need to retune the car twice
Old May 20, 2012 | 03:08 PM
CurseDSM's Avatar
Are you gonna run e85? Those injectors are basically built for that. Fic makes prob the best injectors around. 1000's would be ok, if you go FIC 850s is what your will want and prob cheaper.
Old May 20, 2012 | 05:17 PM
robotech's Avatar
Most likely I will have to tune car twice in any case. As currently it has stock evo4 ecu, but I will go for most likely evo7-9ecu when will be doing turbo upgrade
Old May 20, 2012 | 05:19 PM
robotech's Avatar
I don't have such plans, however guy who does ecu tuning says I should. I want to keep car street legal. I adviced to buy ID of 1000, so it isn't a question - I am definitely buying those.
Old May 20, 2012 | 05:33 PM
CurseDSM's Avatar
No thats cool good luck with the build and the goals. I figured I could just chime in on some extra info for ya.
Old May 20, 2012 | 05:41 PM
robotech's Avatar
Thanx I cannot wait my evo back to the road
