Advice brand for evo8 valve springs and valves?
Old May 14, 2012 | 04:20 PM
robotech's Avatar
BC? Cosworth? any other?
Old May 14, 2012 | 04:24 PM
okevolutionVIII's Avatar
Wouldn't recommend anything BC. I have Manley spring & retainers. When I upgrade to .5mm OS valves, I'm going Manley as well.
Ferrea valves and spring are probably the most common with good results.
Old May 14, 2012 | 06:24 PM
Piro Fyre's Avatar
I personally went Supertech everything. Dual springs and ti retainers, valves, guides, etc.
Old May 14, 2012 | 07:01 PM
domestickillaAR's Avatar
this subject has been beat into the ground just search.. but Kiggly or GSC springs and retainers are good and Ferrea for valves n never worry bout it again (stock size also)
Old May 14, 2012 | 07:15 PM
Levar's Avatar
Veteran: Army
I absolutely love my GSC stage 3 springs and retainers.
Old May 15, 2012 | 10:36 AM
robotech's Avatar
What would you advice?
Twin-springs?
I see big difference in price between cosworth and GSC or supertech. how's the quality?
Engine is evo8 engine with hks cams + now wiseco pistons + eagle rods.
Final goal is about 400hp on small (most likely evo9) turbo so it could have low lag.
Most likely it woud be necessary to make engine run on higher rpm
Old May 15, 2012 | 01:25 PM
Levar's Avatar
Veteran: Army
Twin-springs?
You mentioned 400whp, the stock IX turbo, and high revs all in the same statement. The stock IX will make the 400whp without issue however, it will start to fall off around 7,300 RPM or so. Anything other than that is just how air, my friend. That being said, some nice beehives would suffice. I recommend either GSC or MAP.
Old May 15, 2012 | 01:35 PM
robotech's Avatar
yes, i don't think that getting around 400hp is big problem.
would you recommend twin springs?
Old May 15, 2012 | 01:43 PM
Levar's Avatar
Veteran: Army
No, my friend. I do not recommend dual springs. These are all that you will need.
http://www.maperformance.com/map-bee...p-evo-bsk.html
Old May 15, 2012 | 01:56 PM
evo8in203's Avatar
supertech valves and gsc springs/retainers..
Old May 15, 2012 | 01:58 PM
robotech's Avatar
thank you!
Old May 15, 2012 | 02:04 PM
Levar's Avatar
Veteran: Army
Given his stated goals of 400whp on the stock IX turbo, valves would not be a necessary purchase, my friend. The beehive springs are for an added peace of mind without question. The MAP beehive springs are less than $200 shipped and are well capable to maintain safety beyond what the optimum shifting RPM would be for that specific turbo. His money can be applied elsewhere than on valves.
Old May 15, 2012 | 02:18 PM
Using dual springs actually robs power slightly and stock turbo revs will never need them.
Old May 15, 2012 | 02:32 PM
todd6027's Avatar
lots of horror stories about supertech valves on honda forums
Old May 15, 2012 | 03:34 PM
jonzie04's Avatar
beehive vs duals is a pretty controversial topic. lots of people say the dual spring is old technology and it adds excess weight and wear and tear on the valvetrain as they weigh more. others will go with the beehive, and believe it to be a better design as it weighs less and can get the job done. beehives work well but i would still go with a dual spring simply because if one spring beaks the other can keep the valve from dropping. I broke an inner spring on one of my other cars and the outer spring held on to the valve and saved me a lot of $$ vs if i would have had a beehive....
but all of that aside you do not need either. at 400rwhp and a stock IX turbo and a mild cam. you will not be needing to rev high enough in either the shift points, or at the end of the track to need anything other than the stock springs/retainers. just my 2 cents.
and it is a myth that a dual valve spring will rob horsepower.
