Issue with a dark plug on E85
Old May 31, 2012 | 03:53 PM
Mrauto50's Avatar
I have a MAP 2.3 with FIC 1250 injectors. Motors has 5k mile on it. My car runs fine, but I am getting ready to have the car tuned so I pulled my plugs to make sure everything was ok. This what I had after 300miles.
http://img823.imageshack.us/img823/4...iaimag0226.jpg
I pulled the injectors and each injector looked just like each plug with #3 being the darkest. I cleaned the injectors in Seafoam. They came out like new. I moved injectors 3&4 to 1&2 and 1@2 to 3&4. After 100miles here what I have. Injector 3 was getting black also.
http://img443.imageshack.us/img443/4950/2ndtry.jpg
Any Ideas?
Old Jun 1, 2012 | 04:39 AM
way2qik's Avatar
Any Ideas?
I have had that happen on my car, too. More than likely it is due to air distribution into the cylinders. For whatever reason, this particular cylinder is getting a bit LESS air than the other three, which is causing the rich condition in the cylinder.
The only way to know FOR SURE is to measure the EGTs and to do this you would need EGTs in each header tube. If you have a stand alone like AEM in the car, you can fuel trim that individual cylinder back a bit. This is what I have done. Beginning with very small changes. I started by taking out 1% at a time. I would drive the car again for a couple of days and pull the plugs. Then adjust again... I did this for a couple of weeks. Slowly removing fuel and reading the plug. In the end I took out a total of 4% (at 10lbs of boost or more) from one cylinder to get the plug to read the same as the others around it.
Old Jun 1, 2012 | 03:35 PM
Mrauto50's Avatar
I think I may have found my issue. I think my coil is bad. I will know more soon.
Old Jun 1, 2012 | 05:02 PM
gkania's Avatar
Leakdown test time. oil through the piston ring, sounds like
Old Jun 1, 2012 | 08:22 PM
Mrauto50's Avatar
I hope not, but you never know. The car smells like E85 strong. The #3 three is wet like the injector is stuck but its not. I'm thinking it not firing properly. It has a stutter in the idle. Like a plug. I will do a leak down test to see. Before I put the COP on.
Old Jun 1, 2012 | 08:42 PM
Mrauto50's Avatar
Just wondering. What would cause a Map motor with 5k to loose oil by the ring?
ToxicFab
Aug 27, 2011 11:29 AM
LookThatsMe
For Sale - Cars For Sale
Jun 6, 2011 12:42 AM
xDJ_Aeonx
For Sale - Wheels / Tires
May 1, 2011 10:38 AM
NickieBlaine
For Sale - Part Outs
11
Apr 29, 2011 08:16 AM
H Jensen
Jun 10, 2010 09:55 AM
