Coolant Issues Need some help.
Old Jun 6, 2012 | 05:03 AM
1evo2h8's Avatar
Fixed!
Old Jun 6, 2012 | 05:04 AM
1evo2h8's Avatar
Res for pics
Old Jun 6, 2012 | 05:13 AM
Thegame's Avatar
Did the freeze plug pop out? Look in the back of the block for a small hole. Try filling the radiator up with water to leak check it while idling.
Old Jun 6, 2012 | 05:27 AM
flymx771's Avatar
Nothing in the coolant system runs under the brake booster...do you mean to the left of it? That would be the connections to the heater core, but I doubt you blew one of those off.
From what you said about it not feeling right I'm thinking headgasket.
Old Jun 6, 2012 | 05:49 AM
1evo2h8's Avatar
Problem fixed! thanks guys. And yes I just found that out Fly lol, turns out I was looking at some sort or breather. The issue was the two lines that run to the tb. Since I have an a/m tb They were looped and cracked...going to repalce the line and fire it up..Hopefully it isint the headgasket !
