4G63 with super long rod and 88mm crank
Hi,
Anyone can advice me if I can use a 4G63 engine and 162mm rods and 88mm crank.
I know you can do it with a 4g64 but I am keen on using the 4g63.
Could you guys please advice what pistons I can use with this built?
Thanks
Thanks
Hi,
Thanks for the replies.
So is it advisable to use this set up? I was thinking this would be able to make the engine rev higher ?
Or should I just get the i beams 156mm rod and use the 94mm crank and make a 2.1.
Another question for you guys?
What Mahle pistons would work with the 2.1 stroker. Am intending to use Mahle because of the material used.
I am building a Drag car in Singapore.
Another quick question!
For the AMS drag EVO 2.1 short block
It's usingh the JE pistons ? What size
And 150mm Rods
And 92 or 94 mm Rods.
Anyone knows what size is the pistons ? And also why do they use the short rodinstead of a long rod ?
Thanks
And 150mm Rods
Thanks
[WTB] WTB bare block and crank
jos
May 8, 2017 08:06 PM
[WTB] WTB GSC/BME/94MM Crank
KGB_KGB
Dec 11, 2015 06:18 AM
senate6268
128
Sep 3, 2015 10:44 PM
