A question to tuners about spark plug
Old Jan 29, 2004 | 04:01 PM
gldenchld's Avatar
Have you checked the plugs? you might have a hairline crack in one. I also recommend the IW24's its the same plugs that HKS uses and relabels. If interested I can get the plugs for $12 each.
Old Jan 29, 2004 | 05:19 PM
Want to Evo's Avatar
Originally posted by bluevilevo8
GO WITH DENSO IW24's!!!! I can't believe people are still perpetuating the rumor of "copper plugs are better than iridium.." Copper are better than PLATINUM for a performance application, but the best BY FAR, especially for a highly turbocharged car like ours, is iridium. It is a better conductor, needs less current, and can fire in conditions a copper cannot. The stockers are ok, but not worth the money. They are heat range 7, while the iw24's are heat range 8. Even so, denso tends to be somewhat hotter than ngk when it comes to heat ranges, so their “24” which is supposed to be an “8” on ngk's scale, really falls at about a 7.5.
As for gapping, you want the largest gap possible without causing a misfire. I would recommend gapping between .25-.27. If running 20+ psi, maybe even a little tighter.
You deffinatly want to run the smallest gap pooible without a misfire which should be between .25-.30.
Old Jan 29, 2004 | 05:25 PM
mitsuorder's Avatar
I get no signs of misfire, car just pulls like a biatch but my electronic Greddy boost gauge is acting like it can't keep up with how fast my spool is in 1st and 2nd gear, it is almost like a gear is stripped or something because sometimes it just pegs out and sticks, then I have to rev to build a little boost for it to come back down. I am assuming I would notice a big hit in power if I were misfiring. Do you think that a gap of .028 is too much and maybe I am having some sort of spark "blow out"? Could this be why I'm getting whacked boost spike readings that I don't even think are possible? I know it is not my mbc, because this happened occasionally with my previous controller.
Old Jan 29, 2004 | 05:28 PM
if you had a misfire you would be able to tell. the car would hesitate. If your not having probs at .28 the go smaller to .26-.27. go until you have a misfire and then put it back up just above that.
Old Jan 29, 2004 | 05:35 PM
mitsuorder's Avatar
oops I meant to say not my mbc, corrected
Old Jan 29, 2004 | 06:04 PM
bluevilevo8's Avatar
Actually, you've got it backwards
smaller gap = easier to fire, not as clean a burn
larger gap = more difficult to fire, cleaner burn
Old Jan 29, 2004 | 07:04 PM
What causes the fuel mixture to ignite is a gas molecule passing through the gap in the spark plug as it fires. so if the gap is smaller it is harder to ignite because there is less room for the gas, but the spark is better. A misfire is when there is no gas between the spark plug gap when the spark plug fires thus no combustion. so you want to go as small as possible to get the best spark but not so small that you get a misfire.
Old Jan 29, 2004 | 07:16 PM
I don't know where you get your information, but I can assure you you're mistaken. Misfires occur when the gap is too large, and the flame gets "blown out" (the pressures are too great for the current to jump the gap). YOU WOULD NOT GET A MISFIRE FROM TOO SMALL A GAP. If the gap were too small, it would not fire PERIOD, not just under extreme load / high boost.
Old Jan 29, 2004 | 07:39 PM
all that matters is the best spark is from a small gap.
Old Jan 29, 2004 | 07:41 PM
Not exactly. A larger gap will give a cleaner burn/more power, but is more prone to missing. This is why you want to have the largest gap that doesn't miss.
Old Jan 30, 2004 | 03:22 AM
x7eVoLuTiOn7x's Avatar
I got the IW24's for ONLY $ 7.50 each!!!!
Old Jan 30, 2004 | 03:34 AM
Why do you need to adjust the gap? Theres a sticker on my hood that says IRIDIUM TIPPED PLUG ONLY "DONOT ADJUST GAP". Why are you guys adjusting the gaps? My IW24 has .4mm gap.
Does the IW24 have different gaps? or are they all .4mm? then you just manually adjust them? I was also told by my friend who import these plugs from japan that iridium plugs need not be adjusted. The IW24 are designed specifically for the EVO. He even showed me the DENSO application book.
Old Jan 30, 2004 | 03:47 AM
simevo's Avatar
Want to learn more about spark plug gaps, just go search online. There are tons of info out there that can help you.
And bigger the gap you can get away with without any problem is best for performance. The problem is turbo cars have greater pressure in the cylinder than NA engines making it difficult for larger gap to ignite. Thus, higher boost require smaller gap unless you run after market ignition system like MSD.
So if you've raised boost pressure on you Evo and have misfires, you should reduce the gap on the spark plug or add a more powerful after market ignition.
Old Jan 30, 2004 | 03:55 AM
simevo's Avatar
Oh by the way, too small of a gap can cause detonations. So a right gap is require to run at it's best. And how to find the right gap.
Do a search online for Spark Plug Gap. That should help.
Old Jan 30, 2004 | 07:05 AM
Zeus's Avatar
mmmmmmm... so, where?
