Dynoflash Delivers!!!!
Old Jan 29, 2004 | 05:12 PM
  #31
matt55's Avatar
really?? 2.5" 3" wtf ever ////good #'s on the dynoflash thoe ----stiklr
Old Jan 29, 2004 | 06:00 PM
  #32
Alfriedesq's Avatar
on the 2.5 vs 3" subject - IMHO 3" will net slightly more peak hp - while 2.67 " spools up a bit better and makes better trq
I have dyno verification of this info and Simon Norris as also claimed the same
BTW - all of this deopends on the turbo size, compresion ratio and other mods.
My car for example has the HKS 2.67 " down pipe and makes more trq with the UR high flow cat installed and spools quicker
Old Jan 29, 2004 | 06:05 PM
  #33
matt55's Avatar
werd ?! thanks BIG AL
Old Jan 29, 2004 | 06:14 PM
  #34
MYEVOVIII's Avatar
Old Jan 29, 2004 | 06:38 PM
  #35
Chris in HB's Avatar
How much boost is he running now (the thread starter - I am not sure which name to address...)? I am installing my boost controller and fuel pump this weekend at Pruven (I hope), so I expect to get some nice numbers when I have Al reflash my car... I was planning on running 22 psi - about 1.5 bar.
Old Jan 29, 2004 | 06:58 PM
  #36
Alfriedesq's Avatar
I like to stay at 20 psi with pump gas
We can do some pulls at various boost points to see how it effects power
make sure you call pruven an make arrangements if you need them to install anything - it will be a very busy day
Old Jan 29, 2004 | 07:02 PM
  #37
mikec's Avatar
Originally posted by MYEVOVIII
I also thermal wrapped it due to the heat under the oil pan and I heard that it would help keep heat in and speed exhaust gases better.
Careful. I've cracked headers by thermal wrapping them. Just something to be aware of...
Old Jan 30, 2004 | 08:34 AM
  #38
Stikilr's Avatar
In Timeout
I beleive were only running 17 or 18 psi, i have to check cause i havent mastered the art of reading KPA....my boost guage is reading 17....ill find out today what KPA is reading and if anyone knows let me know.....Al....when er street tunned do you remember what we set it at?? i think it hit like 131 or 130 KPA????? not sure, anyway, you guys are gonna have a blast tomorow from NY!!!!!!
Old Jan 30, 2004 | 09:39 AM
  #39
LordHighBinary's Avatar
Al, on the 2.67 dp, I'm assuming it's hooked up to a 3" high flow, or is it a differnt size?
Old Jan 30, 2004 | 09:56 AM
  #40
CJK's Avatar
CJK
post the dyno sheets
Old Jan 30, 2004 | 10:18 AM
  #41
Alfriedesq's Avatar
yeah - whats taking so long man ?
Old Jan 30, 2004 | 11:40 AM
  #42
4-BNGR's Avatar
DAVE-
PlEASE post "EVO ECONOMY PACKAGE" Dyno figures. Please I want to match the power and torque curves to what you show for your Stage 1 upgrade Kit (which utilizes the 3" turbo back exhaust rather than the 2.5" of the Econo pkg.). I've got a nickle here that says the 2.5" makes more torque. This will be the impetus for you to FABRICATE a 3" flanged "cat back exhaust" with muffler delete pipe style ending - ; one that can bolt onto a 3" HF cat or 3" test pipe. This would make the "ultimate" exhaust for the stock turbo application. Plus mufflers add weight and are for posers, right
ECONO STAGE:
BR EVO VIII AIR FILTER KIT
BR EVO VIII 2.5" DOWNPIPE
BR EVO VIII 2.5" MUFFLER DELETE PIPE
BR BOOST GAUGE PACKAGE
BR MANUAL BOOST CONTROLLER
BR SUPER AFC II WITH BR SETTINGS
STAGE 1 AS TESTED:
FUEL - 94 OCTANE UNLEADED (NO OCTANE BOOSTERS OR RACEGAS)
BOOST - 19PSI
BOOST CONTROL - BR MANUAL BOOST CONTROL
INTERNAL ENGINE MODIFICATIONS - NONE
TURBO MODIFICATIONS - NONE
INTERCOOLER - STOCK
INTAKE MODIFICATIONS - BR AIR FILTER KIT
EXHAUST MODIFICATIONS - BR 3" FULL EXHAUST
CATALYTIC CONVERTER - NONE
ECU MODIFICATIONS - NONE
FUEL TUNING MODIFICATIONS - SUPER AFC w/BR CALIBRATION
FUEL DELIVERY MODIFICATIONS - NONE
http://www.buschurracing.com/EVO8_STG1_VS_STK_LG.jpg
EvoJoeRacing
Jul 5, 2011 10:42 AM
EvoJoeRacing
Apr 19, 2011 12:17 PM
David Buschur
156
May 17, 2008 04:05 PM
AutoMotoSports
25
Nov 10, 2006 07:08 AM
David Buschur
13
Nov 7, 2003 01:27 PM
