help antifreeze leaking from dump tube
Old Jul 16, 2012 | 01:36 PM
EvoChrisLee's Avatar
i have a t3 set up on 44mm wastegate and im leaking antifreeze from the dump tube is it the head gasket or the the turbo checked the oil no coolent in that car is not running hot no smoke in exhaust going to check the plugs later after the car cools
Old Jul 16, 2012 | 01:41 PM
boosted91t's Avatar
The wastegate is pre turbo so you can rule the turbo out.
Old Jul 16, 2012 | 01:50 PM
other than the head gasket what could it be
Old Jul 16, 2012 | 02:24 PM
update no coolant on plugs or on the front/rear of the block or trans just coming from the dump tube
Old Jul 16, 2012 | 02:34 PM
mcm308's Avatar
Well bottom line is this.. there is only two ways coolant can get the wastegate. First is the HG and most likely, 2nd would be a cracked head...
Old Jul 17, 2012 | 11:47 AM
jessmanEVO's Avatar
You can check to make sure that your radiator doesn't have a small leak that may be spraying the dump tube. Just a guess...
Old Jul 17, 2012 | 07:35 PM
GTijoejoe's Avatar
That's what I'd check first.
Old Jul 18, 2012 | 01:28 AM
riceball777's Avatar
the only way I think this is happening is because you have a tial mvr 44mm wastegate which is water cooled. so your water line to the wastegate is probably leaking
