buschur racing maf pipe
Old Jul 31, 2012 | 09:29 AM
DomP's Avatar
When installing the recent mass air flow pipe what do you do with the small vacuum line?
Old Jul 31, 2012 | 09:44 AM
fastyouth1313's Avatar
Picture please
Old Jul 31, 2012 | 11:01 AM
DomP's Avatar
Sorry buschur maf pipe on evo 8. The crank case vent gets the filter kit but theres a small vac line that goes to the oem maf pipe. Therqes no connection on the buschur. Ill get a pic up as soon as i get home
Old Jul 31, 2012 | 03:10 PM
DomP's Avatar
No pic yet, but its a small vac line going into the stock maf pipe. The buschur only recieves the bov and the vent from the valve cover gets the new k&n breather. I just cant find any info in my searches. I know the aem has a small port on their maf pipe. Searching via my phone isnt helping im sure.... any suggestions?
Old Jul 31, 2012 | 03:23 PM
mcm308's Avatar
I forget so refresh my memory... the vac line you are talking about. Where does that go? I believe that comes from the bottom of the oem intake and gets tee'd into something. I think the wastegate.. yes?
Old Jul 31, 2012 | 04:17 PM
DomP's Avatar
Yea it actually goes into a selinoid that's connected to a wire that goes to the mass air flow sensor The other vacuum line goes into the waste gate connected to the same selinoid
Old Jul 31, 2012 | 04:23 PM
mcm308's Avatar
Yep, that be the boost solenoid under the intake filter. The other end of the line goes to waste gate and there is a tee with a line that goes up to the intake... yes ?
Old Jul 31, 2012 | 05:34 PM
DomP's Avatar
Yes sir!
Old Jul 31, 2012 | 05:35 PM
DomP's Avatar
Theres no place to hook it on buschurs maf pipe
Old Jul 31, 2012 | 06:21 PM
EVO8emUp's Avatar
That's the bleeder line. Pressure from the WGA line is bled off to controll boost. The air that is bled off is metered air and is recirculated after the MAS.
Old Jul 31, 2012 | 06:42 PM
DomP's Avatar
So what do i do with that line when instaling the new maf pipe?
Old Jul 31, 2012 | 08:44 PM
ElectricBlueIX's Avatar
Get a manual boost controller, throw it away, and get a tune.
Old Aug 1, 2012 | 03:32 AM
DomP's Avatar
So just throw 200$ down the drain?..... its going to sean ivy in a few weeks. I would hate to not ise this pipe....
Old Aug 1, 2012 | 08:39 AM
mcm308's Avatar
No, you still retain the pipe, install a boost controller with new lines and eliminate the tee. I did mine with a 3 port solenoid. One line from turbo, one line from wastegate to solenoid and I plugged the hole in my oem intake. Kind of simple. Being that you are getting tuned, you will need a way to control boost anyway.
Old Aug 1, 2012 | 08:50 AM
DomP's Avatar
Oh awesome thanks for the info guys. Ill just have ivy put it in when he does the mbc. Sorry to be so noobish lol
