Goal of 400-450hp
Old Aug 20, 2012 | 04:43 PM
Pitch_BlackEvO9's Avatar
Originally Posted by Mistaken
Lots of guys run the s2's. Id upgrade the springs and retainers too.
Ok thanks much appreciated..
Old Aug 20, 2012 | 04:54 PM
Originally Posted by masonh
if you are already at 365whp,just injectors and E85 will get you to 400whp even at the same 25psi.
i don't know much about the EVO 9 turbo other than it;s better than the EVO 8 turbo,but if i can go higher than 25psi,then you should be able to hit 450whp easy at 30psi on E85.
cam,springs,injectors,labor and tune will set you back well over $2000.
you can do injectors and a tune cheap.
it all depends on when the 9 turbo runs out of breath.
I just want to build it right the first time and be done with it but I know owning a car like the evo there always work to be done to it. I know the stock turbo is only going to hold so much I rarely push it hard. In south florida there's no track course that I know of only strips.. I've should have posted this also how much power can the connecting rods of an evo9 hold and safely
Old Aug 20, 2012 | 05:56 PM
silverIXMR's Avatar
a maxed out 9 turbo, stock block, on e85 should put you around 425/425 roughly. the stock block with a good tune should be ok for quite some time at that level. if you want to be safer, run an electonic boost solenoid like the grimmspeed and keep the torque around or under 400 and it will be safer. keep in mind, although exceptional, there are cars running low to mid 600hp on stock block
Old Aug 20, 2012 | 06:26 PM
I've heard about the block holding its more the connecting rods that I've heard that it kills the bottom end. It's a good idea I didn't know with a electric boost controller I can do that. I'll look in to that
Old Aug 20, 2012 | 08:42 PM
jrblackSE's Avatar
Injectors (1100-1450cc), e85 tune, Lower and Upper IC piping. How thick is your Intercooler as well? (3-3.5" will do) A grimmspeed EBC is very nice for ecu controlled boost and costs nearly the same as a Manual Boost Controller (something to look into) and do you have a 3" DP or 02 housing? you are easily looking at 425+ with this combo without cams. Best of Luck with it all!
Old Aug 21, 2012 | 05:25 AM
My IC is a 3.5 and I pretty much have everything except the EBC and the injectors.
Thanks
Old Aug 22, 2012 | 05:32 AM
bighead87's Avatar
i live in miami also ive heard the homestead speed way does road racing sometimes just dont remeber when
Old Aug 22, 2012 | 05:38 AM
bighead87's Avatar
or you can get a tru boost to control your boost levels i want to run a t3/t4 50 trim cause my evo 9 turbo tends to lose boost at high rpms im boosting 26 and it drops to like 22-23lbs
Old Aug 22, 2012 | 09:13 AM
I am in miami also. I am thinking if doing the tur boost also. I am at 25psi and when I am at high rpms it holds at 25psi. Is it normal for the boost to drop at high rpms or is that normal
Old Aug 22, 2012 | 03:14 PM
ev0mATT's Avatar
Go to E85. You won't regret it. Just get injectors and a nice tune you'll be making 400+whp in no time.
As for cams... go for the GSC S2 cams. They are amazing... and they sound great
Old Aug 22, 2012 | 05:02 PM
TurboTal's Avatar
cams, injectors, and a FP red will have you comfortably closer to the high end of your goal.
Old Aug 22, 2012 | 06:11 PM
That's my best bet. With the s2's would you recommend replacing the valvetrain or will the cams do the job on stock internals?
Old Aug 22, 2012 | 06:15 PM
What's the different between the green and the red all I was able to fine was the green is low end power and the red is more mid range power
Old Aug 22, 2012 | 06:22 PM
shrtstuff89's Avatar
How reliable is the e85 I heard about injector seals going bad
The bad on e85....30% less gas mileage....gas stations typically use old diesel tanks and has crud in the tank. So that crud usually clogs injectors. For every few tanks of e85, do a tank of 91/93.
I would recommend injectors with e85, but do a dual tune. So you can switch back and forth from premium to e85 with the touch of a button.
E85 is a great cheap race gas
Old Aug 22, 2012 | 06:33 PM
That was the problem injectors were clogging. That was something I was thinking about doing to different tune one for e85 and the other for 93. It's cheap by my house hope it goes lower lol.. thanks for the advice
