Place to tap for Manual Boost Controller
Old Feb 1, 2004 | 01:43 PM
GottaGoFaster's Avatar
I had my Hallman MBC installed at a DSM shop so I assume they know what the are doing. From the pic (if you can really tell) is this the best place for the MBC to go?
It is the Hallman Evolution, so I can adjust it from the cockpit...I just wanted to know if it was cool were they tapped it.
Old Feb 1, 2004 | 03:06 PM
yes, no, maybe
Old Feb 1, 2004 | 03:21 PM
SuperchargedGTZ's Avatar
that is kind of stealthy...i like that...here is were i put mine.
Old Feb 1, 2004 | 03:24 PM
justchil's Avatar
nm
Old Feb 1, 2004 | 08:41 PM
propellerhead's Avatar
I mounted mine using one of the radiator fan shroud bolts. It taps in directly at the compressor outlet, loops through the valve and goes directly to the wastegate actuator. I hold a steady 19-20 PSI (measured at the manifold) all the way to redline.
