help diagnose culprit
Well..... my clutch journey continues.
My tranny is in perfect health and I've never had grinding in any gear. After the first install of CC stage 2 the clutch it shifted beautifully. No issues at all but I suffered a TOB pop and had to do the job again.
After fixing the TOB clip and installing a new OEM TOB the car shifts fine at low RPM in all gears but grinds going into 3rd and 4th at redline. All other gears shift great.
I have adjusted the pedal both directions resulting in no change. I have tested to see if it is dragging and its not. I know for a fact the tranny is healthy and that the clutch was fine the first time around. The fluid is new OEM ..... Soooo now what?
