Ned help with wobbly shifter.
Old Aug 24, 2012 | 09:34 AM
eboogies's Avatar
Need some info on what can be causing my shifter to feel wobbly in gear and also in neutral? There is to much play in the shifter, i installed the ams under hood and base bushings but still the shifter feels loose.. Thank in advance for the help.
Old Aug 25, 2012 | 05:59 AM
Swaggers's Avatar
Veteran: Army
Is it worse than factory? Are you positive you installed the new bushings correctly?
Old Aug 25, 2012 | 03:25 PM
eboogies's Avatar
Even before i installed the bushings it felt like that, thats why i installed the bushings thinking it would solve the problem. I'm 100 percent sure there installed correctly. After i got my act clutch installed the shifter felt like this.
