evo 8 idle problem
Old Aug 25, 2012 | 03:03 AM
B13 JUS's Avatar
evo 8 idle problem
can anyone point me in the right direction, my evo has started to idle at 2k rpm, what would cause this?
its on a syveck ecu, forged engine.
Old Aug 25, 2012 | 04:31 PM
awdordie's Avatar
tps (throttle position sensor) is the first thing i would check.
Old Aug 25, 2012 | 06:13 PM
TRACK FAMOUS's Avatar
Sounds like what happening to me, I cleaned iac with brake cleaner and right away the problem was gone. Also it would idle weird like it would go higher an lower in the rpm range,
Old Aug 27, 2012 | 07:33 AM
B13 JUS's Avatar
whats the iac? is that the idle control valve?
is a evo 8 and 9 has the same icv? not sure what mine will have as its got a evo 9 inlet
Old Aug 27, 2012 | 11:09 AM
B13 JUS's Avatar
i have just had the throttle body of and found a vacuum pipe of which looks like it goes to a round regulator looking thing, lol
i also removed the icv and turned ignition on, it opened and then closed but it didnt go back to original place, while i did this i spray wd40 on it just in case it was sticking,
when i fitted it again it would'nt bolt up so applied a bit of pressure to close it.
now went to start it and it wont idle now it just stalls, so ive had to adjust the throttle cable to get it to idle.
have i done something to the icv or will it be the vacuum pipe that had blown off?
Old Aug 28, 2012 | 08:28 PM
It's an Evo 8 but I believe it's the same, using that wd40 might of hurt instead of helping because it does leave a Lil residue an those sensors are extremely sensitive
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
evo8tanner
Sep 23, 2016 11:31 AM
9!'clipseDOHC
Jan 9, 2016 10:21 PM
Ogrodii
Feb 11, 2015 03:51 PM
PhoPoweR
MitsubishiParts.net - WA
May 28, 2011 10:00 PM
