Evo 9 sounds like a subaru
Old Sep 11, 2012 | 06:40 PM
evoe85's Avatar
hey guys im having issue with my car. the car spun a bearing before this starting happening.. i received my block and head from the machine shop got everything back together with the same setup. wiseco piston 10:1 with turbo stuff rods, L19 main studs and head studs, 274 gsc cams, dual supertech springs and retainers, supertech valves etc....fp black turbo..newww fic2150cc injectors, neww sparktech ignition , new spark plugs, neww crank position sensor, new map sensor, etc
i tried everything thats possible and still cant find out whats going on with the car. the car on idle is perfect once i rev pass 2000 rpm starts misfiring acting like a subaru. also while drive the car has fuel cut pass 2000 rpm. NEED HELP!!!!
I would appreciate who ever helps me out with this issue.
Old Sep 11, 2012 | 07:02 PM
thatguy5's Avatar
your wastegate might be opening and closing back and forth really bad, mine sounded like a subie because of that problem
Old Sep 11, 2012 | 07:14 PM
Seanc_wa's Avatar
who tuned it...?
Old Sep 12, 2012 | 05:53 AM
evoe85's Avatar
yea i notice that the o2 dump is open.... does it need adjustment?
Old Sep 12, 2012 | 05:57 AM
evoe85's Avatar
email tune by john brandley..
Old Sep 12, 2012 | 06:03 AM
evoe85's Avatar
i got a code p2229 barometric pressure circuit high input
Old Sep 12, 2012 | 07:09 AM
Ev0ikon's Avatar
When you put everything back, did you do a leak test and try to pressurize the entire system to near target boost level before you crank it up the first time?
Old Sep 12, 2012 | 07:40 AM
YogSaahoth's Avatar
Veteran: Army
Is the maf harness plugged in? Assuming its a maf car...
Old Sep 12, 2012 | 09:25 AM
evoe85's Avatar
no
Old Sep 12, 2012 | 09:57 AM
evoe85's Avatar
no maf sensor.. cars on sd
Old Sep 12, 2012 | 12:28 PM
Ev0ikon's Avatar
Also check your Crank Angle sensor. It may be on backward.
Old Sep 12, 2012 | 12:37 PM
Blue91lx's Avatar
I would venture to say that timing is off and/or a cylinder has no compression or isn't firing. In my experiences, the car won't run if the crank angle sensor is on backwards.
Old Sep 12, 2012 | 12:51 PM
evoe85's Avatar
timing is right on the money and i also checked compression 150 across..
Old Sep 12, 2012 | 01:00 PM
fastyouth1313's Avatar
check the plugs. make sure they didnt foul.
were break in procedures done?
if you have exhaust leaking out of the dump tube it could be the wrong gasket. or gasket is blown
when its makes the "subie sound does it sound like its coming from up front? or out the back?
you may need to tighten the preload to make sure the flapper is shut.
also a way to test your wastegate pressure is to by bass you boost controller. take some vacuum line and run it from your j pipe directly to your WGA and see what your boosting that will tell what you WGA is holding preassure wise
Old Sep 12, 2012 | 01:01 PM
also if you have a smartphone. take a vid post it.
