Help! My clutch does not disengage!
Old Sep 29, 2012 | 08:08 AM
SaulHudson's Avatar
Originally Posted by Randal
I looked under the tranny thru the opening and I could see the tob, from what I can see nothing looks wrong but I don't really know what I should be looking for down there. I see the tob attached to the clutch
As I said above, move the clutch fork to see if it works. When the move the clutch fork, the fork should pull the tob, which wil pull the locking rings and that hsould cault the clutch splines to bow out.
Old Sep 29, 2012 | 08:16 AM
Randal's Avatar
Guest
okay i took a picture now on my phone as it is and this is how it looks. I will have to try pushing the clutch down to see how it looks.
Attached Thumbnails Help!  My clutch does not disengage!-photo-2012-09-29-11.14.jpg
Old Sep 29, 2012 | 08:32 AM
Randal's Avatar
Guest
Okay so the tob does seem to seperate from the clutch when the clutch pedal is pushed all the way down. Here is a pic before and after pressing it down. Notice when its pressed down on the clutch tob goes and seperates from the clutch and you can see it goes over the silver wear mark on the shaft.
Attached Thumbnails Help!  My clutch does not disengage!-photo-2012-09-29-11.29.jpg
Old Sep 29, 2012 | 08:36 AM
Randal's Avatar
Guest
The clutch splines do blow out when its pressed.
Old Sep 29, 2012 | 08:55 AM
Randal's Avatar
Guest
I looked at the bottom of the tranny thru the hole and the TOB does move and pull out the clutch splines when the clutch is pressed. so i don't think its the Throw Out Bearing. Slave cylinder boot does not appear to leak out any fluid when squeezed.
Old Sep 29, 2012 | 09:10 AM
Randal's Avatar
Guest
Here are better pics
Old Sep 29, 2012 | 09:12 AM
Randal's Avatar
Guest
Pic 2 when clutch enganged
Old Sep 29, 2012 | 09:39 AM
migs647's Avatar
Randal, I understand you're frustrated, but you can't bump this thread every few minutes. Please be patient
Old Sep 29, 2012 | 10:40 AM
Randal's Avatar
Guest
Mind your place bud.
Bump
Old Sep 29, 2012 | 11:30 AM
winkdogydog101's Avatar
Originally Posted by nytalonTSi
You have air in clutch line. Your technique is also wrong, you don't pump the clutch pedal when bleeding. Push down once, open, close, pull back pedal. Repeat.
Did you pull back the sleeve on the slave cylinder? When they go there is fluid build up in there.
could not have said it better
Old Sep 29, 2012 | 11:36 AM
Randal's Avatar
Guest
I re bleed them the right way and nothing. I pulled back at slave cylinders sleeve and not a single drop of fluid.
Old Sep 29, 2012 | 05:03 PM
Randal's Avatar
Guest
Anybody have any feedback on what can be wrong based on what I have said in the above posts?
Old Sep 29, 2012 | 05:16 PM
ak47po's Avatar
If you can't handle the job take it to a garage.
Old Sep 29, 2012 | 07:02 PM
Randal's Avatar
Guest
First thing I am trying to do is figure out the job, I have no problem doing it myself.
Old Sep 29, 2012 | 07:14 PM
lostsoulsevo's Avatar
hey bro pm, i'll try and help you out over the phone. i'm thinking it might be a bad pressure plate now
