What's wrong? TOB? Pressure plate?
Hi all,
Randomly driving tonight my clutch pedal felt weird, like a bit spongy, then I listened good and could hear a dry squeak noise coming from my engine bay Everytime I pressed down on the clutch. What on earth could this be? I'm so sick of taking this gearbox out lol. First clutch clips now this.
Hi all,
http://youtu.be/Uoykv94nHqw
Air compresses easier than fluid hince the reason your brakes will feel spongie if not bled properly. You need to bleed the slave cylinder until your pedal is firm. It may look like your brake fluid resevoir is full of fluid but the clutch portion is a very small section in the resevoir and can be looked over easily. When bleeding the clutch I always keep the fluid all the way at the top of it and when I'm done I bleed down to the max line.
To me, it sounds like it's one of the springs inside the transmissions bell housing that is connected to the clutch fork that is making that noise, or it is the clutch fork itself rubbing making that noise.
If you get closer where do you hear the noise coming from? Does it sound like it's the slave cylinder? It could also just be that you need to put some grease between the slave cylinder and the clutch fork.
Might not be a bad idea to look through the transmission inspection hole (located in the bottom of the tranny) while you have a friend press the clutch in and out (obviously make sure the car is on a jack stand securely before going underneath it) just to make sure it looks like everything is working properly. This may also help in locating the noise.
That's my .02 anyway.
-Bink
-Bink
-Bink
-Bink
UPDATE! and a good one!
I just got home from work and went outside. I took the slave cylinder off and sprayed some WD40 on the contact points (rod and clutch fork), put it back together and tried it out. Back to normal! Thank God!!!
-Bink
-Bink
