Run car NA
Old Oct 13, 2012 | 03:59 PM
scrivs's Avatar
Run car NA
Breaking in my new motor--would like to do so without boost... Is there any way to bypass the pressure the turbos making (external wg). I guess I could remove the spring from the wg... Any other ideas?
Old Oct 13, 2012 | 04:07 PM
lostsoulsevo's Avatar
or just don't get on it!!!
Old Oct 13, 2012 | 04:12 PM
ExViTermini's Avatar
You should use some boost to break in the new engine anyway....pushes the rings out and allows them to seat on the walls better.
Old Oct 13, 2012 | 11:13 PM
scrivs's Avatar
Yeah, as per my research, that's what I'm thinking to, boost off the wg spring (14 psi)
Old Oct 13, 2012 | 11:21 PM
shrtstuff89's Avatar
Unhook the wga arm. But many a ppl say if its gonna break, itll do it at 5 miles or 5,000 miles and the break in is mumbo. Im pretty sure theres shops that go straight from rebuilt motor installed to dyno in the same day
Old Oct 13, 2012 | 11:56 PM
RSMike's Avatar
+1
bedding in an engine without "decent" cylinder pressures will yield average results.
The best place to run in an engine is on the dyno.
this way detonation and AFR can be monitored real time while the engine is being run in.
Also load can be correctly monitored
Mauricio Evo IV
Jun 2, 2014 01:34 PM
lucid215
Nov 22, 2013 07:55 AM
rstchris
11
Sep 16, 2013 06:56 PM
