How much PSI are you boosting?
19 to redline......I think that BUschur has said that he actually lost hp running higher boost than that. They use 19 max until their stage 4. I am guessing that unless you have mad mods, the higher boost isn't helping to do anything but raise your egt's. Can anyone prove me wrong?
20psi to redline on high, 17psi to redline on low. this works great and seems to be the best set-up I could ind to run safe. Boost controlled by Greddy e-01 and fuel by e-manage. Great unit. Perfect hold no spiking. 93 octane.
I'm running 20 lbs untill redline with a spec 1 Profec B and am occasionally hitting fuel cut for some reason. I called Nino (dynoflash guy) and said a flash would fix that problem because of improper timing and a/f ratio. I'm in chicago where temps fluctuate but 20 psi shouldn't hit fuel cut! Any comments?
