Thinking of switching to a 3 port
Old Nov 13, 2012 | 04:33 PM
asu11's Avatar
Well right now I'm running a hallman pro mbc on my stock motor ix tuned at 28psi on e85. Since weather fluctuates pretty good here in AZ I was wondering if I would be better or going with a ebcs. I overboost quite a bit sometime since it can be 75 during the day and 40's at night. From what I have read they can hold boost better and can be tuned for more specifics such as load or gear based boost. Just wondering what everyone's input was and if it is worth the switch? Any input is appreciated. Thanks.
Old Nov 13, 2012 | 04:47 PM
meckert's Avatar
I use a GM3port--ECM controlled and have almost the same climate and no issues with overboost. Thats why I went with it as well.
Old Nov 13, 2012 | 05:38 PM
asu11's Avatar
Thanks, thats my main reason since the mbc has no control over that.
Old Nov 14, 2012 | 08:21 AM
dastallion951's Avatar
I went with a gruppe s 3 port. I've had a greedy profex b spec 2 ebc, a dejon tool mbc, and not this although adjustments are nice with the mbc, a 3 port is better stealth for one, using our stock ecu u can manipulate the boost profile perfectly unlike the mbc which is a huge peak spike then can bleed off quickly. The profec ebc was a biotch to have setup properly. My advice go with a 3 port....preferably one that is plug n play no wire splicing needed.
Old Nov 14, 2012 | 10:47 AM
Ramen_Noodle's Avatar
I've seen a lot of good feedback on the Grimmspeed 3 port from EVO and STi owners, I'm going to get one myself because of how wild our weather/climate can be around these parts. Worth the extra $20 IMO.
Old Nov 14, 2012 | 10:55 AM
asu11's Avatar
Thanks everyone. Going with a grimmspeed 3port.
Old Nov 14, 2012 | 11:18 AM
XTR Performance's Avatar
If your interested in a deal on the GrimmSpeed 3 ports, we're your place to get them!
$96 shipped!
GrimmSpeed EBCS
Old Nov 14, 2012 | 12:31 PM
Raptord's Avatar
+1 for a 3-port, opens up so many options for tuning. Weather compensation, PSI- or load-based boost control and correction, gear-based boost control...
Old Nov 14, 2012 | 01:15 PM
chu's Avatar
chu
I ran an OEM 3 bar and Perrin ECU boost controller. Nice setup, and easy to install. The Perrin is plug-n-play.
Old Nov 14, 2012 | 01:24 PM
evo8426's Avatar
I'm happy with the Grimmspeed 3 port
Old Nov 14, 2012 | 01:36 PM
SavageEvo8's Avatar
i run the fftec 3-port. boost is smooth and consistent. its design is based off the GM 3-port, but made specifically for evo8/9 use
what about a hybrid ebcs/mbcs setup?
Old Nov 14, 2012 | 02:36 PM
asu11's Avatar
Good to know. Haven't looked much into the hybrid setup. Anyone chime in on this running it?
Old Nov 15, 2012 | 09:38 AM
asu11's Avatar
$96 shipped!
GrimmSpeed EBCS
Thanks! Just ordered one from you!
Old Nov 15, 2012 | 09:51 AM
Ordered received! Will go out for you today .
Thank you for your business!
-Chris
Old Nov 15, 2012 | 11:15 AM
asu11's Avatar
-Chris
Thanks!
