Is it possible to use oil temp gauge to know how long to cool down?
Basically I'm wondering at what oil temperature coking is a possibility, so that if my oil temp gauge shows 60 C I don't have to worry about cool down.
I have had so many ?'s lately regarding what is running at what temp..
So I bought myself an Infrared Temo Gun, now I just point and click!!
http://www.rcmodels.com/1004-1613.html
Very cool tool!
Very cool tool!
Normal operating temperature is 80 to 90 C, unless you are beating on it o the track, then it is around 115 C. I would let the oil Temp hit around 85 C and let your EGT go below ~350 C (with EGT on the down pipe)
it'll probably be long enough if you wait for the oil temp to go down, but the thing is if, independent of the oil temp, you wanna keep oil pumping through the turbo if it was recently spooled up. If its still spinning and the car is turned off and oil pressure is take away.... {thumbdown}
Originally posted by evo542
i heard ralliart is coming with a thermostat eliminator for the oil (super tuner magazine) but they do not recomend it for street use
One of the seldom-weak points of 4G63 is rising of oil temperature. It is seen more often in circuit driving. Evo uses thermo switch that will work when the temperature gets around 85Ž. Yet when the oil temp is low, it will restrict oil flow to the oil cooler and raise the temperature of oil consequently. TOMEI oil thermo killer lets oil to flow into the oil cooler constantly regardless of its temperature. Still, it is easy to put it back to stock thermo switch in winter to prevent over cool.
Re: Is it possible to use oil temp gauge to know how long to cool down?
Very cool tool!
Very cool tool!
