Changing fluids today myself, PLEASE HELP!! Don't want to screw up
Old Feb 7, 2004 | 02:03 PM
CJK's Avatar
CJK
WEll guys, I am looking at the owners manual and it shows:
Manual Transaxel-3qt oil I am using Redline 75w-90
This is the tranny fluid correct? sorry if that was a really stupid question...
Transfer oil- it says .58 qt What have you all used for this????
Differential (rear axel) .58qt Again which oil to use???
Please help me out guys, I am looking to do this within the next few hours....and I need to know this info. badly...don't have a lot of time to search, so I apologize if these questions are lame, but I am stretching for time... HELP
Thank you very much!
Any othe info that I may be leaving out...please let me know!
Old Feb 7, 2004 | 02:15 PM
Compjoc's Avatar
redline MT-90 for the tranny and redline 75w90 for transfercase.
Old Feb 7, 2004 | 02:20 PM
ez76's Avatar
same, and 75w90 for rear diff as well
Old Feb 7, 2004 | 02:35 PM
metaphysical's Avatar
Registered User
Just keep in mind no shockproof without the additative for LSD in rear. Buy a gear oil pump at a parts store...makes it MUCH easier. I squirted it in and it was a major PITA.
Old Feb 7, 2004 | 04:48 PM
CJK's Avatar
CJK
SO manual transfer case is Tranny right?
So I have a rear diff. that needs 75w90
MT-90 for the tranny? in the manual I thought it said 75w90??
Transfer case is 75w90 as well?
HELP ME!!!
Doesn't shock proof come with the rear diff fluid? or is there something else I need to buy to add???????
Sorry for freakin out
Old Feb 8, 2004 | 09:29 AM
CJK's Avatar
CJK
some more help please...didn't do the change because I didn't know what I needed..
So transfer case and tranny oil use the same MT-90?
and the rear diff uses 75w90? I thought the tranny used this...is front diff. the same?
Old Feb 8, 2004 | 09:37 AM
asdf's Avatar
You need to buy 3 quarts Redline MT-90 for the transmission and 2 quarts of Redline 75W-90 for the front and rear diffs.
You should try the search function because it has all the answers you are looking for.
Old Feb 8, 2004 | 05:42 PM
CJK's Avatar
CJK
Thanks asdf!
