'Service Engine Soon'
Old Feb 7, 2004 | 09:49 PM
Evo_toy's Avatar
I installed the B&B turbo back and I can see 'Service Engine Soon'
what should I do to kill it ???
Old Feb 7, 2004 | 09:51 PM
Ryanmcd3's Avatar
In Timeout
Re: 'Service Engine Soon'
Pull the code first. Do a search I typed up something on this before.
Old Feb 7, 2004 | 09:53 PM
Evo_toy's Avatar
I will try to it
Old Feb 7, 2004 | 11:33 PM
1QWKEVO's Avatar
do u have a cat?... no cat= codes...
Old Feb 8, 2004 | 09:29 AM
snoop's Avatar
I fixed the same problem. I got the following information from this thread. It may be a misfire from a spark plug. My light has not turned on since
"another quick way is to open under hood fuse box,pull the two fuses that have what appears to be an engine,1 is the#8 20A fuse and the other is the #15 15A fuse.leave out for at least 1 minute and reinstall.you just reset you ecu,and are all set,no ses lite and no history code either,and like stated above,if there is still a problem,it will come back.The good thing about doing it this way is that the radio presets are not lost and after a while you will notice that your battery terminal end on cable will no longer tighten enough to provide a positive contact(that is after 50 or so times of disconnecting/reconnecting).Hope this helps"
Turbo Dan
https://www.evolutionm.net/forums/sh...t+engine+light
Old Mar 28, 2004 | 04:48 PM
Evo_toy's Avatar
Old Mar 28, 2004 | 04:56 PM
mitsuorder's Avatar
Hey thanks for the tip on how to reset your ecu, I like it a lot better than removing and possibly damaging the terminal over and over.
