Evo 8 antlag and exhaust cut out
Like title states I'm looking to see if antilag is worth it I'm going with 6262 kelford cams etc debating weather I should buy a antilag system for it
Also debating about a exhaust cut out 3 inch thanks would love to hear from people who have had any of these or knows about them thanks
bragging rights and deep pockets , i doubt very much if any such people would be able drive a car with anti-lag .
i believe a full antilag system is definitely worth it. but it reduces turbo life considerably since you are creating combustion in the exhaust manifold. that being said large turbos benefit greatly from it on the track since it whines them back up before gear engagement. as far as the cut out you'd be better off just pulling the back half of the exhaust off since its only 2 bolts. much cheaper then you could actually install a j pipe in its place to keep it from frying your undercarriage.
I second Joseph, it's worth it, it would usually produce 6-8psi over run boost which means that the car would be much faster cornering. However, for drag racing, I'd recommend you use NLTS or 'flat foot shifting' which is much more effective than antilag in a straight line.
