Need advice on BOV and IAT sensor location (going speed density)
Hello EvoM I need your help and advice. I searched on the subject but couldn't really find any info (probably not looking in the right place)
Long story short: I am switching my car to speed density and I am wondering the best location to mount the bov. My old set up was a JMF intake with a Synapse DV recirculated. I purchased a JMF 4 inch intake w/no recirculate to replace old.
Since I am switching to SD there is no need to run a recirculated BOV correct?
Should I mount the BOV to the IC pipe? If so where is a good location or rule of thumb for placement?
Last question I promise, I can mount the IAT sensor on the IC piping as well correct? Placement?
Thanks a bunch in advance!
Tim
This were the BOV reticulates into right now.
Me showing the weld on adaptor, Is this a good place?
new intake
old verses new
Tim
new intake
old verses new
BOV should be put near the throttle body, AIT should be near the intercooler on the lower section of the upper intercooler pipe, and you do not have to recirculate the BOV on speed density.
Thanks for the response boys!! I had no clue the IAT sensor went there, the only pics I have seen where guys tapping there intake manifold.
You have any pics around showing the IAT on the IC pipe?
Thanks again, Tim
Thanks again, Tim
It does help supply air to the compressor , and under racing conditions, the bov is completely sealed from environment .. Mine leaks at idle slightly and I am afraid stuff could find its way to the seat even with a steady stream of venting air
