Aem ems v1 vs v2
Old Feb 25, 2013 | 08:05 PM
evoboy2006's Avatar
Aem ems v1 vs v2
Hey guys I was wondering if there is a drastic different from version one to v2 aem ems if the v2 is worth the money
Old Feb 25, 2013 | 08:27 PM
TheBoz's Avatar
Just USB. AEM has an upgrade coming out for flex fuel support on the series 2. So if that is what you are looking for then yes the series 2 would be hot.
Old Feb 25, 2013 | 08:35 PM
sobo's Avatar
Uh, I beg to differ.
EMS 2 has one GIANT difference; Throttle response.
Also, USB, Software, ease of starting.
/thread.
Personally, I would not run the EMS 1 again after driving an EMS 2 car.
Old Jul 23, 2013 | 07:31 PM
Wickedwhite8's Avatar
My aem v1 may have died yesterday. If I go v2 will the tuning have to be started from scratch again? I have 12 hours into this v1 and would like to transfer it over to the v2. Is it able to do this? Thanks in advance
Old Jul 24, 2013 | 05:42 PM
foxbat's Avatar
@wickedwhite there is an AEM EMS section under the ECU tuning forum, I think you might get a better answer over there.
Going back to the original topic, I've heard that V1 has proper anti lag capability while with the V2, anti lag doesn't really work, is that true?
Old Jul 24, 2013 | 07:51 PM
TheBoz's Avatar
Not true. You just need to set it up correctly. If you want to lock the timing at -17* you need to set it up. On the series 1, it was fixed at -17*.
Err,
Unless you mean rally anti lag. I have not played with rally anti lag on the series 2. Most people call 2step, anti lag. So if you mean it in the drag racing context then my previous answer was correct.
Old Jul 25, 2013 | 01:35 AM
foxbat's Avatar
Yes rally or overrun anti lag not launch control w/anti lag.
I've heard that it doesn't work on the V2 like in other aftermarket ECUs such as the Vipec, Hydra...etc
Old Oct 20, 2013 | 11:16 AM
detroit pistins's Avatar
So do you guys connect to the V1 via serial cable vs USB in the V2 case?
I am debating the switch from the stock ecu to a V1.
Thx
/thread.
Can you elaborate on the response difference you felt with the V2? are there different features offered in the V2 to allow for better response?
Thx
Ronnie Size
May 15, 2016 11:10 AM
DDATuned
May 9, 2016 09:14 PM
Anubis18
Apr 4, 2016 05:05 AM
christian_21
Nov 9, 2015 07:46 AM
Theitalianjob76
Aug 31, 2015 02:56 AM
