Build Advice Evo ix
Old Mar 14, 2013 | 10:42 AM
rmorr79's Avatar
Build Advice Evo ix
Okay so im starting to get everything together for my build and need some advice on a few things here and there. Im going to be running E85, the car will be used mainly as a street car with occasional track use, im looking to be in the 500-550 whp range.
Current Mods:
Ets FMIC and piping
Stock Turbo
ported exhaust manifold
3 inch turbo back
Titek o2 housing
kelford 272
Supertech dual springs and retainers
L19 headstuds
walboro fuel pump
Fic 1100 injectors
wideband, boost, egt
Future Mods:
2.3 stroker
2150 fic injectors
Map EF3/FP Red/GT35r
Ported intake manifold
Ported throttle body
Exedy twin
Shep transmission and t-case
Double pumper
Old Mar 14, 2013 | 10:47 AM
bboypuertoroc's Avatar
Veteran: Army
... so what advice are you looking for? Looks like a solid list as it is.
Also, if you're gonna go Red, just go Black. I had a Red, blew it, upgraded to Black, and noticed zero difference between the two other than the Black pulls harder and obviously has more power potential.
Old Mar 14, 2013 | 10:57 AM
rmorr79's Avatar
Mainly in regards to the turbo situation and fuel set up. From my understanding I should be alright on the stock fuel rail and FPR. I've heard good things about both the Map turbo's and FP. At this point i'd be sending out my stock turbo to get rebuilt and MAP is substantially cheaper in regards to the rebuild. I already have the 35r at my house so I would need the manifold,dp,ect.. which would run close to the cost of the upgrade to the stock turbo
jerrymldz
Apr 1, 2014 04:04 PM
Booztd3
Dec 30, 2013 04:00 AM
ChefJMB
Jul 16, 2013 08:37 AM
ApacheToYaDome
Jun 6, 2013 04:48 AM
killercd4G63
35
Nov 4, 2012 02:08 AM
