Fuel on top of pistons?
Old Apr 7, 2013 | 08:13 AM
ReignMan24's Avatar
What would cause fuel to be on top of pistons 1-3, and the spark plugs wet from the fuel as well?
Old Apr 7, 2013 | 08:27 AM
evolve_VIII's Avatar
It's running rich or your injectors are sticking open.
Old Apr 7, 2013 | 08:36 AM
ReignMan24's Avatar
rich is an understatement lol but thank u for the response, I think i'm gonna pull them and send them off to FIC. neone else have ne ideas on wat it could b
Old Apr 7, 2013 | 08:52 AM
pensport's Avatar
Injector issue, I had a similar problem and it ended up being a short in injector wire in the wire harness causing injectors to be stuck open and dumping fuel .. Could it Possibly be ignition issue not burning the excess fuel
Old Apr 7, 2013 | 08:59 AM
ReignMan24's Avatar
once I get this excess fuel sucked out, im gonna throw new plugs in and see if it is ignition related. Also, what did u do to resolve the harness issue.
Old Apr 7, 2013 | 10:14 AM
ReignMan24's Avatar
neone else?
Old Apr 9, 2013 | 08:35 AM
make sure that you clean all the fuel out, change the oil and put oil in the cyinders or you will be burning up the piston rings.
Old Apr 9, 2013 | 04:59 PM
hiboost2.0's Avatar
Take a long flat head screw driver, put it on on top of the suspected injector and put the handle end up to your ear. You should hear a ticking sound, that's the injector pulsating open and closed. If you don't hear anything then it's stuck open.
Diamondstar90
Jul 18, 2012 10:34 AM
JSPturbo
Mar 13, 2011 02:52 PM
konstantinosIX
33
Apr 23, 2009 06:05 PM
