IAC issue?
Old Apr 27, 2013 | 10:32 PM
xXANCHORMONXx's Avatar
IAC issue?
Hey on my 8 my idle sucks
I have full bolt ons including 272 kelford a.
When I roll into neutral the car stumbles to 500 rpm and sometimes dies and sometimes recovers.
I replaced my iac with a used one with no luck so I may buy a new one but my tuner also said I may have shorter the ecu as well?
Is that possible?
Anthony
Old Apr 28, 2013 | 09:41 AM
Bump?
Old May 28, 2013 | 02:56 AM
JorgeYaHeard's Avatar
I have the same issue, but it's intermittent. Did you find a fix?
Old May 28, 2013 | 08:19 AM
thedru13's Avatar
Did you check for boost leaks? Also check the TB could be leaking seals.
Old May 28, 2013 | 08:22 AM
evolve_VIII's Avatar
You may need to adjust the idle screw on the throttle body. This will compensate for more air flow through the engine. I doubt the ecu is shorted. It either wouldnt idle or set codes. Boost leaks will also cause this problem as well. Is your BOV recirculated or vent to atmosphere?
Old May 28, 2013 | 08:53 AM
PureDrivePerformance's Avatar
We've got most of it sorted out. He had several issues with his idle tune.
The main issue OP is having now is the fuel pump re-wire. It's over 60 psi at idle so it's going extremely rich after open loop and bogging it down. We're waiting on the Spoolin Up Plug and Play Highl Low Re-Wire kit.
GSXPimp
Feb 17, 2016 06:15 AM
mtschmidty
May 27, 2015 09:27 PM
nckmc517
Apr 28, 2015 02:44 PM
mrm95
Dec 18, 2013 06:45 AM
ct9asilver
21
Jul 25, 2012 08:23 AM
