Engine dies @~5500 rpm wot
Old May 11, 2013 | 09:13 PM
211Ratsbud's Avatar
If I wot the car it runs til about 5500 then acts like the key was shut off. Does this sound like an obvious defect in any of the sensors? Cam cam crank? Evo ix.
Log to come
Old May 11, 2013 | 09:20 PM
Anarchy99's Avatar
Fuel cut?
Old May 12, 2013 | 02:33 AM
211Ratsbud's Avatar
No very smooth feeling
Old May 12, 2013 | 09:37 AM
211Ratsbud's Avatar
The car doesn't come back on, it stays off as long as you keep wot.
Definitely not any type of rev limiter
Old May 12, 2013 | 09:38 AM
st0mp860's Avatar
Limp Mode?
Old May 12, 2013 | 09:54 AM
4RETECH's Avatar
I would look into fuel. Seeing as you back off the throttle it is better.
Check pump pressure and volume, but usually that you would hear as a lean misfire pop before it shuts down....
Old May 12, 2013 | 10:16 AM
211Ratsbud's Avatar
I have a spare ecu as this one has some bad ram.(from what we gather) I'm gonna swap and see if that's the problem that's manifesting
Old May 12, 2013 | 10:39 AM
ZanarkO's Avatar
I had the same problem do you have a factory intake on the car? The intake "cup" or schoop that comes to the hood gets sucked up to the hood at WOT and then it just Falls right on its *** and its like pinching a star while trying to suck air through it.
Old May 12, 2013 | 10:43 AM
ZanarkO's Avatar
*straw* Also sounds like your intake tube may be collapsing or you popped off an intercooler pipe. Idk Im just throwing examples. boost test your car and make sure your vacume lines are connected on your passanger side below the intake manifold by the FPR. I know my buddy running 33psi on his FPRED blows off EVERY SINGLE vacume hose from the factory when it hit that boost level.
Old May 12, 2013 | 12:40 PM
211Ratsbud's Avatar
No fap 84mm + 84 tube. I brake boosted and couldn't replicate the problem. Only happens when the motor is accelerating fast.
Old May 12, 2013 | 02:22 PM
ZanarkO's Avatar
is it the silicone tube or metal? I know on subarus they have issues with the turbo inlet collapsing at high power levels.And at brake boosting your not hitting your max boost. so essentially your saying at partial throttle you can go all the way to redline but full throttle at 5000rpm it falls on its *** and shuts the car off? you restart drives fine partial throttle still? What are you AFR's when your hitting this "wall". Also have you recently had your timing belt changed? Theres a sensor down there (cant remember which one think its the crank position sensor) which can go out if its hit during the change, its a possibility that may be your issue as well. It will be random at first and gradually get worst as time goes on.
Old May 12, 2013 | 02:39 PM
211Ratsbud's Avatar
The symptoms are not an intake restriction, since the car stays off until you let off the throttle. Meaning you could coast to a stop with your foot to the floor.
Old May 12, 2013 | 02:46 PM
ZanarkO's Avatar
So your saying once you go full throttle at high rpm it will shut off but if you let off the gas it will start back up again? And what about partial throttle will it go past 5500?
Old May 12, 2013 | 02:58 PM
211Ratsbud's Avatar
Yea , I'm not gonna comment too much further until I get a log .. I was mainly interested if it sounded like a typical crank cam or cam sensor.
Between mommas day and the new baby to and from work are my logging times lol.
Ill get back with a log
Old May 12, 2013 | 03:14 PM
ZanarkO's Avatar
ok lol, but from what you say sounds like the crank sensor. My buddys MR had similar issues.
