I havent seen my rad fan come on in a while.....
Old May 12, 2013 | 03:52 PM
88888's Avatar
Exclamation I havent seen my rad fan come on in a while.....
I had my car over heat the other day on track and now im thinking it may be fan related issue.
My ac fan has been removed and my AC is out of the car as well.
But i just noticed that my rad fan never turns on on idle or even after hot runs.....
I have CBRD rad with aftermarket fan. What couldve gone wrong here?
Is there a way to test my fan to see if its broken?
THanks
Old May 12, 2013 | 07:18 PM
88888's Avatar
bumping
Old May 13, 2013 | 09:18 AM
88888's Avatar
i need some opinions...
Old May 13, 2013 | 10:26 AM
MechTech's Avatar
Number one check your fuses, then check your relays. Then supply 12v to it and see if it turns on. Or see if there is a setting in tephra to turn the fan on and off. Check your grounds. See if the temperature being reported to the ecu from the sensor is accurate. Check fan on/off parameters. If all that checks out ok, start looking for broken wires.
Old May 14, 2013 | 12:20 PM
CBRD's Avatar
all good stuff-
yes- certainly hook the fan directly up to voltage-
we have seen issues with the oem fan controllers and now tend to hook alot of the cars up with a temperature controlled thermostat that runs off a relay/the battery- so its independent- you also get much higher flow-
cb
Old May 15, 2013 | 06:21 AM
Travis@GSC's Avatar
If its over heating "on track", I assume you are talking road race track...you have another issue than the fan. Moving at high speed will put enough air flow over the rad to cool it, having a fan on will not add more air flow when doing 50+ MPH. Most race cars do not have rad fans because they restrict flow at high speed.
rev the car to 3000 RPM for 3-5 min and see if the fan comes on, or check you ECT and see what it actually is doing.
Old May 15, 2013 | 07:21 AM
CBRD's Avatar
the other thing to check- if its an active cooling issue-
is your radiator cap-
we are finding evo after evo now with weak radiator caps- whether it be on a koyo, mishi, our rads, or oem-
they will purge into the overflow and most people dont realize it-
we have fixed quite a few cars that way-
cb
Old May 19, 2013 | 08:05 PM
88888's Avatar
cb
thank you for your response CBRD.
what rad cap do you suggest that I run? I own the HKS rad cap at the moment. part number or model number would be great
Old May 20, 2013 | 09:52 AM
matrho2792's Avatar
http://www.streettunedmotorsports.co...p_1350a730.htm
Old May 20, 2013 | 11:33 AM
wang4u's Avatar
Any 1.3 bar cap will work just fine. The stocker is 1.08 bar, not suggested for track
silentkiller
Dec 14, 2013 08:47 PM
414Evo8
Jul 18, 2013 05:15 PM
88888
May 20, 2013 01:13 PM
DirtyRalli
Jan 19, 2013 03:17 AM
utggevox
Jun 10, 2012 04:30 PM
