Electrical HELP ASAP
Old Jun 2, 2013 | 09:49 AM
Triplenickle's Avatar
I have a 03 evo 8. A few nights ago, it started to loose power and the lights went dim and all the gauges went off. It eventually lost all power and drained the battery then died. Luckily I was able to get it off the freeway and to a safe spot. I got a jump it fired right up good for 30 sec then gradually lost all power and died again. I was thinking the turbo timer was messing it ( its kinda intermittently worked if it was moved like a loose connection somewhere in it). So I just unhooked the timer from the harness that splices into the factory harness. Jumped he car and again runs like a champ then 30 sec later no power and dies. The alternator was brand new as of a month ago. Do I need to uninstall the turbo timer harness from the factory too? Any other ideas? I just had the car tuned last wed at English racing, could it be an ecu issue? Thanks for the help I'm lost right now not too good with diagnosing electrical.
Old Jun 2, 2013 | 09:54 AM
michaelrc51's Avatar
I would say it is your alternator.
Old Jun 2, 2013 | 11:26 AM
05VIII's Avatar
check the alternator fuse in the fuse box in the engine bay
Old Jun 2, 2013 | 11:28 AM
gsrboi80's Avatar
Wouldn't be that if you can charge the car and it fires back up
Sounds like a bad Alternator to me
Old Jun 2, 2013 | 11:54 AM
I haven't technically "charged" it just a sime jump then it dies. I will charge the battery and see if it will run until the charge is gone.
Old Jun 2, 2013 | 06:36 PM
That is kind of what our are doing when you jump it..... Then your battery runs down and your car dies cause your alternator is not putting out like it should.
Posted from Evolutionm.net App for Android
J8dailo
Mar 1, 2017 10:08 AM
byebyesubbie
40
Sep 15, 2016 06:25 AM
ninjacoco
Lancer Engine Tech
Nov 25, 2014 08:43 AM
minstmeat
Sep 4, 2013 08:02 PM
J8dailo
Oct 29, 2012 05:39 AM
